Bad Steering Shaft? - Mustang Evolution
Old 04-28-2014, 09:42 AM   #1
WheelStander's Avatar
Bad Steering Shaft?
I think I have a bad steering shaft. As I turn the wheel I hear a click click click coming from the u joint or by the firewall I can't tell exactly where.
It's definitely in the shaft somewhere around u joint on the firewall I'm just wondering do I replace my whole shaft or is there a bearing somewhere that is making that noise that I need to replace.
Any information or comments are appreciated.
Induction: Kenne Bell | wHp: 515 Tq: 503 | 1/4 Mile:11.09@123
WheelStander is offline   Reply With Quote
Old 04-28-2014, 04:16 PM   #2
I'm guessing that the whole shaft needs to be replaced if that is indeed the source of the noise. I don't think that there are any serviceable parts.
I would expect, though, that you would be able to feel the noise that you are hearing through the steering wheel.
Id get someone to sit in the car and turn the wheel while you stand outside and listen for the source of the noise.
Old 04-28-2014, 06:43 PM   #3
Thanks ...no play, cant feel anything in the wheel. Feels like I can grab the knuckle on one side and pull...looks like there is the slightest movement in the u joint so im thinking knucle is starting to go bad.
Car has 99, 000 and has had some issues with dry rot on some of the rubber a d plastic parts from sitting out side.
steering shaft foxbox 1979-1995 Mustang GT 2 03-14-2014 09:46 AM
Intermediate steering shaft? ccabral14 1996-2004 Mustang GT 2 12-30-2013 08:15 PM
Steering shaft clamp and bolt 2.3Foxbody 2.3 Mustang 5 11-16-2012 04:23 PM
Steering shaft issues.. 2013_stang_gt 2011-2014 Mustang GT 8 10-31-2012 08:01 AM
Can you interchange a 1965 mustang steering wheel with a 1967 steering wheel? gruffudd91 Classic Mustangs 1 08-26-2009 04:38 PM
02:01 AM
