Head gasket maybe?.... - Mustang Evolution
Old 04-29-2014, 11:18 AM   #1
Grrrr....'s Avatar
So I've got a 98 Mustang GT that I bought 6 months ago for 2800. The interior is great and it drives straight as hell but I think it needs a new ball joint. After replacing a ton of sensors and the fuel pump, filter, and IAC valve, I did a cylinder compress test today and found cylinders 2 and 4 have low compression (about 80 psi low, and it misfires and idle surges and dies). I've only put about 300 into it, and I'm not dumb when it comes to fixing cars. I'm just wondering if it's worth it to replace the head gasket. The car still runs, and no smoke out the exhaust, just a lot of fumes. I have seen coolant on a spark plug. My thought was to replace it before it gets bad, or sell it to some poor bastard for what I bought it for. I need to know how much it would realistically cost with basic garage tools and if the effort is worth it. My budget is about 200-300 bucks. I wanted to do PI heads, but not really willing to fork up that kinda cash. Thanks for your time guys, any input is welcome.
Grrrr.... is offline   Reply With Quote
Old 04-29-2014, 01:37 PM   #2
Slow4V's Avatar
Sorry but your going to need at least 1,000 ..
Take in mind if your replacing head gaskets.. Your heads are probably warped .. Which means you have to go take them to a machine shop to get them resurfaced .. And wait and pay whatever their labor is which may be a couple hundred.
Plus. Head gasket set .. And new head bolts .. Gasket and bolt sets would be like 2-300 by them selfs , you'll need a very good torque wrench which can run up to 500+.00 .. Something like this needs to go to a professional if you don't have to knowledge or the tools.
Plus tearing about the timing chains and everything else isn't a walk in the park.
I say sell the car while you can, if you can. That's just my opinion
Old 04-29-2014, 02:27 PM   #3
Ogre's Avatar
If the head gasket is your whole problem, it's well worth your time and effort to fix it. RockAuto has head gasket sets for less than $135. You definitely want to do both heads. Now, once you tear into it, you may find that you need other things like timing chain, tensioner, and things of that nature.
Your heads aren't necessarily warped because you've blown a head gasket. After time and miles, head gaskets wear out. Once the heads are removed, you can check the surface with a straight edge to see if they need to be taken to a machine shop. I've done many head gaskets without needing the heads shaved. Vehicles still running strong after many years.
If you need special tools like torque wrenches and pullers, you can rent them for free at local auto part stores. Basically you give them a deposit and get your money back when you bring the tool back.
Here is what your looking at for costs, best case scenario:
Head gasket set - $130
Oil and filter - $30
Coolant - $15
Head bolts - $60
Vehicle manual - $15
Ogre is offline   Reply With Quote
Old 04-30-2014, 12:13 AM   #4
Grrrr....'s Avatar
1000 bucks?!? I did a head gasket on a 94 civic for under a hundred a few years back. I plan on renting the torque wrenches and special tools. I've been browsing and found a kit that includes head bolts for 115. I'm gonna tackle it. If anyone has tips or advice that have done this before I'm all ears. Other than that, thanks for the input. Time to hit the garage!
Old 04-30-2014, 11:52 AM   #5
Ogre's Avatar
Where did you find a head gasket kit w/ head bolts for $115?
Old 04-30-2014, 12:26 PM   #6
96GeeTee's Avatar
Region: Maine
A few years ago, I blew the gaskets in my old 3.8 and warped the heads. I had everything remade from scratch by a performance/machine shop that specialized in the 3.8 motor, and after all was said and done it was about $2000 including install, which isn't a terrible price for what is basically a brand new motor. I'm pretty sure the 3.8 heads warp a lot easier than the GT ones though, or so I've heard.
96GeeTee is offline   Reply With Quote
Old 04-30-2014, 12:27 PM   #7
Slow4V's Avatar
Take it to a professional
That's my advice
Old 05-01-2014, 07:35 PM   #8
Grrrr....'s Avatar
I found a kit on Late Model Restoration for 115. If I have to take the heads to a machine shop then so be it. Just ordered the kit.
Old 05-01-2014, 07:37 PM   #9
Ogre's Avatar
Good luck! Thanks for the info.
Old 05-11-2014, 07:59 PM   #10
do a wet compression test first if that doesnt improve your results do the head gaskets with higher compression gaskets and arp head bolts. a lil more money but a lil more power and serviceable for the future. as posted earlier have your heads checked and decked if needed. do not skip that step or you will kick yourself in the *** later.
eccy_1 is offline   Reply With Quote
Old 05-11-2014, 08:12 PM   #11
XSlashDashX's Avatar
Replace motor or pi swap. In the same boat. About to swap motors.
Upper intake plenum gasket and EGR gasket McNassty General Mustang Discussion 1 06-08-2012 10:51 AM
Is a valve gasket the same as a valve cover gasket? birtingr General Mustang Discussion 6 03-15-2010 02:24 AM
leaking head gasket tedness Pre-2005 V6 Mustang 5 03-07-2005 10:06 PM
leaking head gasket...what? tedness The Bar 1 03-07-2005 09:43 PM
Cracked Head or Head Gasket problem DMustanger Pre-2005 V6 Mustang 21 12-17-2003 06:52 AM
03:53 PM
