First Mustang need advice - Mustang Evolution
Old 04-30-2014, 10:18 PM   #1
TheJoeBailey's Avatar
I just got a 2000 GT with 142k miles replace serpentine belt sent abs module off for repair changed oil changed power steering fluid looking at spark plugs and coils which do you recommend also if you could do all over where would you start with modsClick image for larger version
Name:	ImageUploadedByMustang Evolution1398917875.174218.jpg
TheJoeBailey is offline   Reply With Quote
Old 04-30-2014, 10:29 PM   #2
dcm88's Avatar
congrats on the first mustang ! if you do change plugs and coils make sure you have a torque wrench .There is a sticky post on what to do . as far as a first mod i think you can't go wrong with a catback or short throw shifter if you have a manual.
dcm88 is offline   Reply With Quote
Old 04-30-2014, 10:57 PM   #3
Mile high JDF's Avatar
Wheels and lower it should always be the first things done. Clean the MAF sensor and change the fuel filter as well.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 05-01-2014, 06:57 AM   #4
Great advice thanks it seems that after much research a Bama tune is a major contributor to gaining hp and torque
Old 05-01-2014, 08:44 AM   #5
96GeeTee's Avatar
Region: Maine
Depends on if you want to go for performance, or looks. Could get any body work done, fresh paint, wheels and tires. For performance, I would just start with a nice exhaust system and then start in on the bolt ons. Maybe go with some 3.73 gears if its a manual, or 4.10 if an auto. The sky is the limit (or rather, your wallet is.)
96GeeTee is offline   Reply With Quote
Old 05-01-2014, 01:44 PM   #6
NGK spark plugs or OEM Motorcraft?
Old 05-01-2014, 03:37 PM   #7
V6 stang's Avatar
Motorcraft
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 05-01-2014, 04:38 PM   #8
Thanks
Old 05-01-2014, 05:15 PM   #9
Autolite 103s are the plugs you want. Mod motors like one range cooler. For the coils, rebuild the stockers with a $30 kit from Amazon or rockauto. If you need new coils because the old ones are totally shot then get them from rockauto and only ever use motorcraft cops.
Sent from my VS980 4G using Mustang Evolution mobile app
First new car, first mustang, first ford Sportsman New Member Introductions & Greetings 21 11-20-2015 02:59 PM
my first mustang need advice busaboy 1979-1995 Mustang GT 11 05-17-2013 07:37 AM
First Mustang...First Ford...First Car This Awesome! Debster New Member Introductions & Greetings 13 04-28-2013 12:30 PM
First Post, First Car, First Mustangg EdgeLivin New Member Introductions & Greetings 14 04-03-2012 12:49 PM
First Mustang - First Post - Need litte advice Just_John New Member Introductions & Greetings 12 08-02-2011 10:54 AM
02:01 PM
