LED cluster bulbs , HOW TO - Mustang Evolution
Old 05-02-2014, 05:20 PM   #1
Slow4V's Avatar
Tools needed
Needle nose pliers
Electric Impact
Torx T20 long / Short
Pick
Name:	ImageUploadedByMustang Evolution1399072785.049891.jpg
First oh ahead and remove the headlamp switch & the trim that covers the cluster
( 2 ) T20 Screws
Name:	ImageUploadedByMustang Evolution1399072507.266995.jpg
There's going to be 4 T20 screws in the four corners , go ahead and remove them.
Name:	ImageUploadedByMustang Evolution1399072585.350380.jpg
Once you undo the 4 screws, pull forward the cluster , and disconnect the 2 Connectors in the back.
Once you have it out , go ahead and remove the bulb sockets by twisting left
Name:	ImageUploadedByMustang Evolution1399072673.259312.jpg
to remove the bulbs I found it easy to use a pick and poke through the back.
Name:	ImageUploadedByMustang Evolution1399072715.948803.jpg
Name:	ImageUploadedByMustang Evolution1399072736.714747.jpg
Insert the LED bulb to the socket
Name:	ImageUploadedByMustang Evolution1399072748.091605.jpg
And repeat the process
Name:	ImageUploadedByMustang Evolution1399072815.131843.jpg
Old 05-02-2014, 05:21 PM   #2
Slow4V's Avatar
Going to probably change them to a more white tint, I'm not a big fan of the " cool white "
Old 05-03-2014, 10:19 PM   #3
Back from 2008
Not on this forum tho.
I've got this mod done to the cluster and HVAC and did it to my 95 Cobra I had as well. Takes about 5 minutes to have the cluster out and another 5 back in. HVAC is a little more if a pain but its worth it.
Replacement LED bulbs GP3GT 1996-2004 Mustang GT 0 06-12-2012 10:03 PM
LED taillight bulbs? Blackedout Pre-2005 V6 Mustang 1 04-09-2012 07:44 PM
LED instrument panel bulbs sixty6fastback Classic Mustangs 3 02-07-2011 02:12 AM
LED turn signal bulbs cterie 1996-2004 Mustang GT 1 05-07-2010 10:05 AM
11:30 AM
