Rough idle - Mustang Evolution
Old 05-04-2014, 08:31 AM   #1
Jrh2592's Avatar
Rough idle
My 04 GT is idling very rough, it sounds like it wants to stall at red lights. I am going to clean the IACV today with some carb cleaner and pray that does the trick. Any other tips for diagnosing/fixing the problem?
Jrh2592 is offline   Reply With Quote
Old 05-04-2014, 09:57 AM   #2
Jrh2592's Avatar
Well I cleaned the IAC with no luck. However, when I was taking it off to clean, I removed the rubber hose below it that is attached the the plenum, and there seemed to be oil in it. I have been searching around to figure out what the hose is for to see if that's normal or not but I can't find anything. Anyone have any thoughts?
Name:	ImageUploadedByMustang Evolution1399218971.458773.jpg
ID:	155837Click image for larger version
Name:	ImageUploadedByMustang Evolution1399219028.218308.jpg
Old 05-04-2014, 10:07 AM   #3
Im pretty sure that hose comes from the PCV valve. And I believe its normal to have a little oil in it. Its a vacuum that comes from the crank. so the air will probably have some oil particles in it as it travels through the system.
2012 Mustang Cyclone, 2002 Mustang GT, 2004 F150 FX4, 1999 Ranger O/R 4x4, 2007 Harley FXDB
jefx is offline   Reply With Quote
Old 05-04-2014, 10:09 AM   #4
There is a way to install an inline catch can to collect the oil before it reaches the plenum if you are concerned about it. You can buy them, or even make your own at Home Depot.
Old 05-04-2014, 10:10 AM   #5
Jrh2592's Avatar
If it's normal, than I'm ok with it. I just wanted to make sure that was the case, thank you!
Old 05-04-2014, 10:14 AM   #6
Ive read advise saying that if an IAC is bad it should just be replaced. and that cleaning it wont do much if it already isnt working right. just fyi
Old 05-04-2014, 10:15 AM   #7
Jrh2592's Avatar
I found that out the hard way unfortunately haha, I'll be ordering a new one shortly
rough/surging idle dragonlouie 1979-1995 Mustang GT 25 08-23-2008 07:59 PM
ROUGH IDLE joseandmarilyn 1979-1995 Mustang GT 8 09-27-2007 11:39 PM
My car seems to idle rellay rough, and miss badly johnpittbull 1979-1995 Mustang GT 21 07-04-2006 09:06 AM
Rough Idle and Rough Start Cajun JungleBoy Pre-2005 V6 Mustang 3 04-23-2006 10:33 PM
MIL P1414, rough idle BlueDonkey Pre-2005 V6 Mustang 7 11-13-2003 11:27 PM
03:09 PM
