Alignment help with camber bolts - Mustang Evolution
Old 05-05-2014, 08:58 PM   #1
The_Chech's Avatar
Okay so I searched for a good while reading different threads about alignments, camber bolts and caster camber plates and didn't get the answers I was looking for proper measurements. The set up I'm running now so you get an idea, I have the H&R super sport (vert) lowering springs (2"f, 1.6"r), SR caster camber plates and I just ordered the Camber bolts to help out getting my camber back because I know -2.1 left front camber is a bit steep vrs the right being -1.4. I was in the shop when he did the alignment because he didn't know where I wanted it at, so I ball parked it and tried to get right at -1.0 on each side but it seems with the SR caster camber plates I've maxed them out.
Now the caster is at +2.1L and +1.7R any idea where this should be at? Never really messed with caster before because I used to be into 4x4's and lifted trucks before I switched to the Dark side as my wife says lol!
As for the toe its 0.14L and .10R so that's close enough
All in all I guess my question is where so I really want my alignment at now that my springs have had some time to settle. And I daily drive the car too if that helps any.
And the car now pulls to the right not sure if its the brake guide pins being a little stuck and forcing the the wheel to be guided that way or if its the new tie rod I was forced to install after the old ones threads were jacked up installing the springs and struts.
Any help will be much appreciated
The_Chech is offline   Reply With Quote
IRS camber bolts Butch SVT Mustang 0 10-26-2012 06:12 PM
bolts bolts bolts! bcosta56 1979-1995 Mustang GT 8 10-10-2012 03:08 PM
Camber bolts a good option? austinknoll Pre-2005 V6 Mustang 12 09-10-2012 06:34 PM
Caster Camber Plates or Camber Bolts OutlawGT 2005-2010 Mustang GT 18 04-05-2012 04:55 PM
Eibach camber bolts bullitt1075 General Mustang Discussion 2 11-29-2011 11:18 PM
11:16 PM
