97 GT pi swap time or junk it? - Mustang Evolution
Old 05-06-2014, 09:56 AM   #1
XSlashDashX's Avatar
Okay so I bought this car as a project. Paid $1500 with 112K miles on it. Originality the guy didn't want to fix the intake manifold leak so he sold it to me. I fixed it up and got it running for a couple months until recently I figured the Head Gaskets are bad. Took it down to my mechanic and got a Compression test and it came out good but coolant is getting into the Combustions? As in the Heads could warped, bad, or the gaskets and he doesn't want to jump into it. Told me to junk the car or buy a rebuild motor for it. What y'all think? Is it worth keep going or just get a different motor?
Old 05-06-2014, 07:01 PM   #2
nyeturbo1968's Avatar
Do you have the money??? And the time?? I just picked up a 97' for 4300.00. I'm having a motor put in it.
nyeturbo1968 is offline   Reply With Quote
Old 05-06-2014, 07:03 PM   #3
It'll be a month or two project but was just wondering if it's worth keeping. Bottom end is good, just heads may be warped and need head gaskets. Call a few shops and all said around 1300-1600 bucks to fix. Figured either pi swap or pull a motor from a salvage car.
Old 05-06-2014, 07:46 PM   #4
This one I just bought. Kinda a project car. I like the look and it will complement my two others. The only other issue will be the exhaust. I think you scored better than me!! I'd go for it..
Old 05-06-2014, 07:48 PM   #5
Yeah before the head problem. My girlfriend won best class trophy at a car show. Click image for larger version
Name:	ImageUploadedByMustang Evolution1399427265.193119.jpg
Old 05-06-2014, 07:50 PM   #6
V6 stang's Avatar
A year or two ago y mechanic back at my parents house said it would be 1800$ to put a 4.6 including labor with about 60k on it into my car if something even went wrong. There's so many, that they are dirt cheap. I would tell them to hook up a pi 4.6 and call it good for couple hundred bucks extra. Have a nicer newer engine and a faster one
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 05-06-2014, 08:15 PM   #7
Well. Good luck..
Old 05-06-2014, 08:39 PM   #8
If the rest of the car is in really good shape which it looks like it is. Grab a PI motor from the JY and swap it in. Get one out of an 02-05 Explorer if you can so you get the WAP block.
You paid next to nothing for the car so even at like $1500 to get it running again you could still get your money out of it. You could also just have bad valve stem seals but you might as well PI swap it regardless. I mean if you didn't want to do the motor just get some PI heads/cams and a new PI intake. PI swap cars are actually a little faster than PI cars or a car like mine that has a whole PI motor dropped into it since you get a pretty solid compression bump putting PI heads onto a NPI shortblock.
And as far as parting it... hell I see nearly $1500 right in that pic. Wheels/tires for $600 if they are good, hood for $300-$400, front bumper for $200 if its in good shape. I'm assuming the driveline is fine besides the motor and if its a black interior there is another $400-$600 for just the interior. That's not even getting into the small nit stuff that ppl will pay for.
Old 05-06-2014, 11:00 PM   #9
Ok.. I'm dumb.. What's P.I.?
Old 05-06-2014, 11:44 PM   #10
DutchManDann's Avatar
PI swap it and let it live! you can pick up a perfect PI engine for under $500. if you want to do the work yourself it's almost a direct swap.
I don't wanna see another decent SN95 junked
Roxanne- 1998 Mustang GT Convertible: 5-Speed, 2001 PI 2V swap, o/r h-pipe, Magnaflow catback, MGW shifter,
3.73 gears, Auburn LSD, TA diff cover, MM FLSFCs, Ford Strut Tower Brace, J&M SS Brake Lines, and a lot of visual/restoration work.
DutchManDann is offline   Reply With Quote
Old 05-07-2014, 07:18 AM   #11
Mile high JDF's Avatar
Performance Improved. On the 99 GTs Ford redesigned the 4.6 modular heads and bumped the horsepower from 220 to 260. They called them the Performance Improved heads.
The heads themselves may have been placed on another car before the GT, but that's all I can remember about them.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 05-07-2014, 08:44 AM   #12
The car has a new paint job with a few rock chips. It's bone stock to the ford exhaust lol. Has the FR500 rims with new tires. The interior is black and grey but previous owner replace the grey seats with black leather seats out of 01 Mustang. I've been looking around on eBay and craigslist for either a motor or pi heads and hardly found anything. eBay wants at least 1500 for a motor. When I have a day off I will go to the JunkYard and see what they got.
Old 05-07-2014, 10:45 AM   #13
www.car-part.com
Old 05-07-2014, 12:22 PM   #14
Thanks Mile High!!
---------- Post added at 06:22 PM ---------- Previous post was at 06:21 PM ----------
Are those the so called "Stage" Heads?
Old 05-07-2014, 12:51 PM   #15
No, PI heads are PI heads.
Old 05-07-2014, 01:00 PM   #16
I've seen Stage 1, Stage 2, and Stage 3. I tried to get a Mechanic to put Stage 2's in my Mach 1. He refused?? I don't get it?? Performance Improvement, it that a brand?
Old 05-07-2014, 01:25 PM   #17
Nah PI is just the name assigned to the updated heads from Ford.
The various "stages" of heads refers the the amount of porting and polishing that has been done to them
Old 05-10-2014, 11:42 AM   #18
Didn't look at the receipt from mechanics until today and saw this in comments lol
Technician Found: has internal motor problems, failed block test, cracked in heads, gasket, warped heads, recomend new motor, car too old for repairs, totaled out, radiator old, coolant reservoir bad and leaking, p1443 evap, po430 cat system, po175 too rich.
Old 05-10-2014, 02:21 PM   #19
V6 stang's Avatar
Damn lmao sounds like it's time for a new motor
Roush Exhaust
Old 05-10-2014, 02:38 PM   #20
Do what Scotty said, find a junkyard motor 01-04. I installed one in my old 96gt and had zero issues. I had to make a very small mod on the coil pack brackets but it looked like it belonged. You won't regret it, more power and better sounding exhaust.
Bigshow14 is offline   Reply With Quote
Old 05-10-2014, 02:39 PM   #21
My 98 has a 99 motor in it. Drops right in and the stock tune on the NPI is fine. Any 99-04 will do it.
Old 05-10-2014, 04:04 PM   #22
Yeah. Think I could get anything from the old motor after swapping
Edited. Also after swapping motor do I need to convert to the coils on top or can I retain the coils I have now?
Old 05-10-2014, 04:35 PM   #23
Retain. You won't get anything for a blown npi
Sent from my VS980 4G using Mustang Evolution mobile app
Old 05-10-2014, 05:09 PM   #24
+1
Old 05-13-2014, 04:42 PM   #25
Found an 2004 crown Vic motor with low miles and for a good price. Swapping should fit my 97? Should I worry about the 6-8 bolt crank or no?
Old 05-13-2014, 05:41 PM   #26
That will have a 6 bolt like yours.
Old 05-13-2014, 06:12 PM   #27
Sweet thanks!
Car junk.. Out with the old, in with the new.. maybe MonteCitan The Bar 9 04-14-2009 09:33 AM
What's my junk car worth? RedMatrix Classic Mustangs 28 02-29-2008 03:34 PM
Star Trek junk on eBay *WW* Ken The Bar 22 03-27-2006 04:06 PM
Junk? 232stang01 Pre-2005 V6 Mustang 16 03-27-2006 11:37 AM
10:37 PM
