Help Idle Problem - Mustang Evolution
Old 05-07-2014, 12:24 PM   #1
TheJoeBailey's Avatar
Help Idle Problem
In Park 2000 GT idles at around 800 but in Drive it will idle at 700 then every so often I drops down below 500 sounds like it might die. Any suggestions
TheJoeBailey is offline   Reply With Quote
Old 05-07-2014, 12:30 PM   #2
Doubledeee99's Avatar
Try cleaning the maf sensor and idle control valve, vaccum lines, plugs...Mine did opposite and idled at 1800. I ended up having to replace the icv 3 times this month so you can start by cleaning them.
Doubledeee99 is offline   Reply With Quote
Old 05-07-2014, 01:35 PM   #3
Jgrummz's Avatar
Easy thing to check is your spark plugs. Mine idled kind of like that except a little worse and it ended up my spark plugs were toast.
Name:	ImageUploadedByMustang Evolution1399491316.373455.jpg
Jgrummz is offline   Reply With Quote
Old 05-07-2014, 01:38 PM   #4
Ok thanks I cleaned MAF and Idle control I also swapped out spark plugs and boots
Old 05-07-2014, 04:52 PM   #5
1lowGT's Avatar
Fix it?
Old 05-07-2014, 07:06 PM   #6
Looks like it fixed. This Stang is like a different beast now thanks
Old 05-07-2014, 10:44 PM   #7
Lol nice man
Old 05-08-2014, 12:36 AM   #8
larrysgt's Avatar
Fuel filter helps too
larrysgt is offline   Reply With Quote
Need help with idle problem 89notchbeast 1979-1995 Mustang GT 17 04-20-2013 01:10 AM
Erratic Idle problem solved-Intake manifold vacuum leak Mercedez L. 1979-1995 Mustang GT 7 07-30-2010 09:08 AM
Idle Problem Help!! W225110 1979-1995 Mustang GT 7 03-30-2010 07:12 PM
Idle problem McGrail482 Pre-2005 V6 Mustang 4 07-13-2009 09:56 AM
94 3.8 off idle hesitation problem crash Pre-2005 V6 Mustang 3 07-14-2008 06:19 PM
01:58 PM
