Stock/90MM MAF Question - Mustang Evolution
Old 05-07-2014, 06:12 PM   #1
Tiffsobelle's Avatar
So I searched around for the answer and got some help, but not quite what I needed, so I figured I would ask you smart folks.
I'm trying to figure out what size MAF is on my car. Sounds weird, right? Well, I need to know for a tune. The PO didn't give me a run-down of what all he had done to the car when I bought it, and I didn't really think to ask. Come to find out, there was quite a bit already done to the car, so I have no idea about the MAF. It did have a screen on it after the MAF where it goes to the filter, I had to take that out and just put in a gasket. The screen didn't fit in the correctly and didn't seem to seal too well.
I did read somewhere that the stock MAF is 80mm, which converts to 3.15in and 90mm would convert to 3.54in. but that didn't say OD, ID and which side and well, I'm a bit of a noob when it comes to MAFs. I do think it might be stock, though.
So enough of the rambling, here's some pics and hopefully someone can give me an idea...
EDIT: After all that, I believe I answered my own question.. The MAF I have has the metal that lines the holes where the bolts go. In the pictures on AM, the 90mm lightning does not have any metal in the holes, So I do believe mine is stock.
Tiffsobelle is offline   Reply With Quote
Old 05-07-2014, 06:30 PM   #2
Rm360's Avatar
It's a 80mm there are two wYs you can tell the first is the sensor itself the letters in the second row on the sensor have the code afh80, that right there tells you the size, the second way is the dimension you showed , the o.d. ( outside diameter is 3-1/2 a 90mm is 4"", here are a couple pics of my 90 Click image for larger version
Name:	ImageUploadedByMustang Evolution1399508993.416089.jpg
ID:	156211Click image for larger version
Name:	ImageUploadedByMustang Evolution1399509040.833101.jpg
Old 05-07-2014, 06:31 PM   #3
Ahh, thought so.
Thank you so much!
Steeds 90mm CAI, 175. shiped Gil_T2 Mustang Parts for Sale and Wanted 3 07-16-2012 08:59 PM
95 5.0 MAF upgrade to a 80mm 2000 4.6 MAF chatanaka36 1979-1995 Mustang GT 3 07-03-2012 08:57 PM
90MM MAF DarkShadow Mustang Parts for Sale and Wanted 9 11-29-2006 10:11 PM
05:54 AM
