2004 mustang gt rough running with ac on - Mustang Evolution
Old 05-10-2014, 07:09 AM   #1
Have 2004 mustang gt has procharger Full exhaust Msd coils etc etc. Issue started bout 5 years ago. Could go to car wash. Wash in out under hood upside down drive out runs fine . Next time barely rinse it off & it's was like injectors went wide open.then would sit for couple days & was fine.but the last time it happened it didn't clear up after sitting.spoke with procharger they figured maybe moisture getting in mafia so replace factory mass with lightening mass & eliminate mafia.runs better but still stumbles / misses.hasn't bin driven in almost 4 years has 12,000 miles other day I found it runs perfect with defrost or ac off.it's bin to 3 ford dealers & 2 dyno shops!! To no avail seems like tried everything any of any sort would be more than appreciated! Thx for ur time
pepe Girard is offline   Reply With Quote
Old 05-10-2014, 07:17 AM   #2
TheJoeBailey's Avatar
I am a noob but don't believe that owners manual recommend washing under the hood with a hose. For me I cleaned MAF sensor didn't clear up idle problem then replace fuel filter cleaned Idle Air Control Valve with a new gasket then replace boots and plugs runs like new now no problems.
TheJoeBailey is offline   Reply With Quote
Old 05-10-2014, 07:28 AM   #3
I just rinse off engine never bin problem with any other vehicle or this one before.have cleaned or replaced everything could think of before brought it to dealer replaced o2 sensors, frps, coils,fuel filter,Injectors,plugs. Am thinking now that found it runs fine with ac off if not as simple as a low voltage issue even though it charges fine.dunno. I'm stumped as well as everywhere I bring it
Old 05-10-2014, 07:54 AM   #4
Hmmm. Well there's your problem.
Your car is sleeping with the fishes.
2012 Mustang Cyclone, 2002 Mustang GT, 2004 F150 FX4, 1999 Ranger O/R 4x4, 2007 Harley FXDB
jefx is offline   Reply With Quote
Old 05-10-2014, 08:04 AM   #5
jokes aside, I dont think its wise to pressure wash the engine. It is engineered to be guarded from the elements such as rain, snow, sun, etc. Thats why it is enclosed on 5 of its 6 sides, and the fender wells have splash guards.
Why are you pressure washing the engine in the first place? If it's getting that dirty from just driving the car, then I think you have some major issues.
Old 05-10-2014, 09:22 AM   #6
Mfore33's Avatar
If it is running bad with the ac on it could be that the ac is about to go out. A worn out ac will have low oil in it and will pull more power away when running. My be time to get a new compressor and flush the system.
Old 05-10-2014, 11:33 AM   #7
Nope. Nothing wrong with ac is either a wiring short when power put to ac or the lower rpm / voltage drop throws maf for a loop. Or is what it seems like. Picking up car from dyno shop today to do some more digging.was wondering if anyone else ever came across issue like this. Car has no miles. Always stored inside moisture got/ gets it somewhere shouldn't Somehow
Old 05-10-2014, 02:39 PM   #8
probably from this:
2004 mustang
4.6 running rough / misfire 96Roushgt 1996-2004 Mustang GT 17 01-10-2013 10:53 AM
Car is running rough Nick.ward Pre-2005 V6 Mustang 9 01-09-2013 06:53 AM
Running Rough. ColeJohnson 1996-2004 Mustang GT 25 09-12-2011 03:46 PM
1999 ford mustang, running rough when getting hot? Grady 1996-2004 Mustang GT 1 03-08-2010 11:50 AM
Rough Idle and Rough Start Cajun JungleBoy Pre-2005 V6 Mustang 3 04-23-2006 10:33 PM
03:53 PM
