MAF Housing - Mustang Evolution
Old 05-12-2014, 12:09 PM   #1
Jrh2592's Avatar
MAF Housing
I was doing a little routine under hood check last night and discovered that my MAF housing is cracked at each corner around the bolts. Does anyone know where I could pick up just the MAF housing? The sensor is still perfectly fine
Jrh2592 is offline   Reply With Quote
Old 05-12-2014, 03:45 PM   #2
Adogg's Avatar
I would check rock auto or partsgeek. Both are going to be pretty cheap. While you have to out you might as well remove the maf and clean it.
Don't hate....... appreciate
Old 05-12-2014, 03:46 PM   #3
Jrh2592's Avatar
Good call, I'll definitely be sure to do that. And thanks, I've been having a tough time finding them without the sensors included
Old 05-12-2014, 04:01 PM   #4
Adogg's Avatar
Hey man having trouble finding it on those two sites I have you but I did find a few of these on eBay, they are cheap and come with a censor. Click image for larger version
Name:	ImageUploadedByMustang Evolution1399932100.273620.jpg
Old 05-12-2014, 04:03 PM   #5
Adogg's Avatar
Have you also tried local parts stores? Like autozone, pepboys, advance auto, and oreillys?
Old 05-12-2014, 04:12 PM   #6
Jrh2592's Avatar
Honestly I just found it was broken last night, so I didn't get too deep into looking around. I appreciate your help man! That eBay one will probably be perfect. Do you know if I'll need a gasket too?
Old 05-12-2014, 04:18 PM   #7
Adogg's Avatar
Not a problem man, honestly if you go that route and get the one on eBay with the censor I would check out the one it comes with and if it's in really good shape use that one over the one you have in the car now. And yea I would throw a new gasket in there, when I did my cai It came with a new one so you might as well.
Old 05-12-2014, 04:22 PM   #8
Jrh2592's Avatar
Awesome thanks for the tips man!
Old 05-12-2014, 04:23 PM   #9
Adogg's Avatar
Good luck man.
95 5.0 MAF upgrade to a 80mm 2000 4.6 MAF chatanaka36 1979-1995 Mustang GT 3 07-03-2012 08:57 PM
MAF housing??? USMCSS 1996-2004 Mustang GT 42 04-22-2007 04:59 PM
thermostat housing Warfire80 1996-2004 Mustang GT 14 09-16-2004 11:00 AM
More Axle Housing Interchange Qs ?? FUNK 49 Pre-2005 V6 Mustang 9 01-17-2004 12:43 PM
AIR FILTER HOUSING MODIFICATION Donny B Pre-2005 V6 Mustang 1 08-20-2003 09:43 AM
05:58 AM
