4.6 2V Price?? - Mustang Evolution
Old 05-13-2014, 07:42 PM   #1
08Mustang's Avatar
4.6 2V Price??
How much should I pay for a 2V with 112,000 miles on it. Just the engine itself
08Mustang is offline   Reply With Quote
Old 05-13-2014, 08:16 PM   #2
Few hundred
Old 05-13-2014, 08:46 PM   #3
08Mustang's Avatar
Gotcha, looking to 4.6 2V or 3V or even 4V swap my 08 V6 rather than supercharge it.
Old 05-13-2014, 08:50 PM   #4
Screaming Mach's Avatar
Your going to need more then just the motor.
Screaming Mach is offline   Reply With Quote
Old 05-13-2014, 08:51 PM   #5
08Mustang's Avatar
I know that.....
Old 05-13-2014, 08:53 PM   #6
08Mustang's Avatar
With a 3V all id need is a PCM and a 8.8" rear mostly cause I've got an auto tranny.
Old 05-13-2014, 09:00 PM   #7
BigB227's Avatar
I'd say keep it as simple as possible and just swap the 3v
BigB227 is offline   Reply With Quote
Old 05-13-2014, 09:02 PM   #8
08Mustang's Avatar
4.6 2V Price??
Yeah that's what I'm leaning towards. Although they seem to run for quite a bit more money.
Old 05-14-2014, 06:17 AM   #9
08Mustang's Avatar
What all would I need for a 2V swap?
Old 05-14-2014, 10:40 AM   #10
Well definitely a needed up front suspension because you will be adding 100 pounds to the nose from the iron block. You'll need motor mounts that work for it, K member may be able to work. Full wiring harness, transmission that will fit it ect....
Old 05-14-2014, 10:43 AM   #11
08Mustang's Avatar
In other words....even though the 3V costs more for the engine, overall price will be probably cheaper and less of a headache to install
Old 05-14-2014, 11:17 AM   #12
Most likely
Old 05-14-2014, 11:18 AM   #13
If you are going to go through the trouble of an engine swap do something unique. Like I'm thinking of doing a 5.4 4v swap.
Old 05-14-2014, 11:22 AM   #14
That would be sick!
Old 05-14-2014, 11:25 AM   #15
08Mustang's Avatar
I'm swapping but on a budget so I don't wana get too complicated. I'm gona swap a 3V cause that'll be the easiest to drop in and require the least amount of custom work.
Old 05-14-2014, 11:25 AM   #16
4.6 2V Price??
Originally Posted by Screaming Mach View Post
That would be sick!
Look in the "2000 GT 4.6 build or swap" thread" in this section, I talked more about it.
Old 05-14-2014, 11:26 AM   #17
1lowGT's Avatar
5.4 4v HCI. Baaaaaaalls yeah torque whore
Old 05-14-2014, 06:53 PM   #18
If you have a 3V stay with a 3V. Going to a 2V is going backwards and a 4V is a little complex for a S197. Yeah they are more but you'll need the PCM from a 2V, wiring harness, fuel stuffs among other things. Will be cheaper to just get a replacement 3V.
Old 05-14-2014, 09:22 PM   #19
08Mustang's Avatar
No I've got a V6 so I'm swapping a v8
Old 05-14-2014, 09:26 PM   #20
Then I would suggest selling your V6 and buying a V8. Will likely be cheaper and much less work. You'll still need to upgrade the PCM/harness/fuel/driveline/motor.
Old 05-14-2014, 09:35 PM   #21
Allans03ragtop's Avatar
If it were me I would just trade for a GT. In the long run it will be cheaper and all you have to swap is the keys. Just saying
03 Sonic Blue CONVERTIBLE W/STYLE BAR AND SPEEDSTER COVER AND 18X10W/275/35 REAR AND 18X9W/245/45 FRONT. OFF ROAD X-PIPE 40 SIERIES FLOMASTERS AND CAI.
Allans03ragtop is offline   Reply With Quote
Old 05-15-2014, 05:48 AM   #22
That and the re-sale on a nice clean GT is going to be higher than a nice clean V6 with a GT swap no matter how well the swap was done. Case in point is a V6 "Terminator" that was completely swapped from a wrecked donor down to the correct nuts/bolts and super low mileage recently sold for about half of what a real Terminator is worth on another forum I belong to. The guy drove it for about a month before just deciding to use it as a donor for a Terminator powered Bullitt because, in the end, it was still just a V6. The Bullitt is a numbered collector car which makes sense to swap the Terminator drivetrain into IMHO.
What would be a good price for a 1971 mustang grande coupe that is priced at 5k? Price negotiable.? Rodric Classic Mustangs 3 12-23-2011 04:17 PM
Best price for Al flywheel TheSarge Pre-2005 V6 Mustang 7 11-28-2003 10:20 AM
What's the going price for a 1999 mustang v6? Thomas91169 The Bar 9 09-16-2003 06:07 PM
dualie for a good price... dark Pre-2005 V6 Mustang 35 07-31-2003 10:23 AM
3.73 Gears --- Anyone know where I can get the best price? Danger Dude Pre-2005 V6 Mustang 2 07-15-2003 11:59 AM
01:32 AM
