Track Times!!!! - Mustang Evolution
Old 05-13-2014, 09:22 PM   #1
Track Times!!!!
Hey Guys, I'm running a 2004 Mustang Gt Auto getting ready to head to the track, an was hoping to get some info on making a better a track time this year, last year I ran a 15.7 was my best with just intake an exhaust. Now I put 3.73's with an AirRaid CAI and have a Bama tuner now was looking on getting a bigger TB what 1/4 time am I looking at with just the setup I have now..? what would I need for now before ..? upgrading to a supercharger is My Plan but just low on Funs..?
Nephewz is offline   Reply With Quote
Old 05-13-2014, 09:42 PM   #2
Mile high JDF's Avatar
I'll be generous and give you a 15.3
What altitude are you at? Any suspension work or decent tires?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 05-13-2014, 09:47 PM   #3
I'm from Colorado my suspension is still stock
Old 05-13-2014, 10:13 PM   #4
Damn all the Colorado guys are showing up now. Bandimere or Pueblo? Unfortunately these cars are choked down pretty hard at this altitude so don't expect major gains in your time without some boost.
If you plan on supercharging it later then look into getting your suspension set up good and get some tires to help put down the power. You can make all the power in the world but that won't do anything if you can't get it to the ground.
Old 05-14-2014, 09:11 AM   #5
Site Sponsor
Sponsor
AMWill's Avatar
I'm on the same page as Mile_high_JDF. You're going to need some suspension upgrades in order to put the power to the ground. Good tires will help a ton too. At the drag strip your 60' means everything!
As far as power upgrades, I see you're planning on upgrading the TB soon. A larger TB is a solid upgrade, but you won't benefit from it nearly as much without changing the upper intake plenum too.
I suggest checking out the SR Performance throttle body, in 70 or 75mm, paired with the SR upper intake plenum. You'll see a much better boost in power with this combo than just a throttle body and stock upper plenum.
Hope this helps you out a little buddy! Hit me up if there's anything else I can do for you.
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 05-14-2014, 09:15 AM   #6
Slow4V's Avatar
Drag Radials , 410s , Suspension work, put the car on a diet, get shift kit or a driver mod, and that car should see low 14s
Old 05-14-2014, 09:18 AM   #7
Slow4V's Avatar
My buddy went 13.5 &10something
Mods
Longtubes Pacesetter
X pipe Pacesetter
Catback LM1
Drag Radials (17psi) MTs
Upper and lower rear control arms UPR
Short shifter Steeda
70mm BBK Throttle body
Trickflow Plenum
Typhoon Intake Manifold
Cold air intake SR
21lb injectors
BlowbyRacing Email tune
And he missed 4th gear, blowing his engine that run,
Old 05-14-2014, 08:03 PM   #8
thanks for the info appreciate it Fellas, Migh High JDF was looking forward to Bandimere but I have a slight problem lol unfortunately I got in trouble in my car and got caught with a Dui so I don't even know if Bandimere will let me race with a restricted license, but ill still want to throw mods on her as much as I can do if any other mustang owners get together any where in colorado...? I'd like to show up
Old 05-14-2014, 08:14 PM   #9
It doesn't hurt to ask them, who knows, maybe they'll let you run. As far as Colorado owners on this site there isn't too many. I'm about the only active one. A lot of guys off the local forums like heading out to sonic meets on Friday nights. If you're local to westminister and ever need help installing mods then hit me up. I've done most of the bolt-ons to these cars already
Old 05-14-2014, 10:07 PM   #10
Ok most definitely yea I hit up the sonic meets to like on federal an the one on 120th for sure I'll be in touch thanks for the help
Old 05-14-2014, 10:50 PM   #11
Yeah the one off 104th and Federal is full of a bunch of ricers and *** holes for the most part. I know some of the mustang guys try to meet up at 120th and Washington
Old 05-15-2014, 10:14 PM   #12
Yea that's true lol Well I'm thinking of running bye this Friday on a 120th an checK it out
Old 05-18-2014, 12:58 PM   #13
edross's Avatar
my 03 gt auto ran 14.0
2003 gt, sct custom tuned by VMP, k&n fipk, upr o/r x-pipe, dynomax turbo mufflers, mm c/c plates, mm full length subframe connectors, h&r race springs, bullit rims 18x10 rear 18x9 front, 4.10 gears, 20% tint, 9 inch shorty antenna
edross is offline   Reply With Quote
Old 10-13-2014, 09:42 PM   #14
P0430 Code
Hi Guys, I recently have a problem my check engine light happen to come on, So I ran my tuner on it to check it out and it gave me code P0430, Does anybody know how I can fix this problem I would appreciate it Thanks.
Ugliest car ever.. and regal track times.. MonteCitan The Bar 21 06-04-2008 04:07 PM
Good times, good times fast64 The Bar 22 11-29-2005 01:16 AM
Update on track times timpryor Pre-2005 V6 Mustang 9 01-17-2005 10:28 AM
Pick up 2003 Auto on Sat, going to track on Sun, what times? Jime Pre-2005 V6 Mustang 30 11-04-2004 11:33 AM
Im heading out to the track tonight! **TIMES ARE POSTED** Zim Pre-2005 V6 Mustang 20 07-21-2003 10:14 PM
06:03 PM
