Rpms hanging while shifting - Mustang Evolution
Old 05-14-2014, 01:49 PM   #1
Hey guys I'm having an issue with my car. It's a 02 mustang gt when I shift my rpms stay at about 2000 - 2300. They drop down after about 4 seconds. Have any of you had this problem before?
blackstang4.6 is offline   Reply With Quote
Old 05-14-2014, 06:38 PM   #2
The RPM's are supposed to "hang" in between shifts but if you think that there is something abnormal about it, like the RPM's are too high or they are staying high for too long, then the problem is probably a worn-out Idle Air Control valve. If you do replace the IAC I recommend using either the OE Motorcraft part or a unit manufactured by Hitachi.
Old 05-15-2014, 08:07 AM   #3
cliffyk's Avatar
Here is how to test the IAC; and more info about the Hitachi and Nippon-Denso OEM units...
Rpms hanging Slow4V 1996-2004 Mustang GT 7 05-10-2014 06:18 AM
Weird rattling while accelerating at around 1200-1500 rpms. Veracadoro Pre-2005 V6 Mustang 21 02-14-2014 05:01 PM
RPMs hanging fix? calebnaasko 1996-2004 Mustang GT 5 07-10-2013 10:14 PM
Shifting in low rpms Shelby121993 Shelby Mustang 3 05-07-2012 08:38 PM
engine's rpms go up and down while driving mike the spike 1979-1995 Mustang GT 6 12-21-2005 08:31 PM
03:22 AM
