Spark plug Wire? Help - Mustang Evolution
Old 05-17-2014, 12:06 AM   #1
Stang805's Avatar
]I need help with choosing spark plugs wires, Today I decided to look at my spark plugs on the 98 gt I just bought and its had some autolite double platinums in OK condition. I went ahead and bought the motorcraft fine point platinum plugs. The thing is that I don't know the age of the wires and if they need to replaced. if so what kinda should I get like 27.99 Napa wires or duralast, Etc. Don't want to put anything major because only performance upgrade I will make is intake and exhaust right now ?
thanks in advance.
Stang805 is offline   Reply With Quote
Old 05-17-2014, 12:11 PM   #2
Www.Rockauto.com and get the $50 motorcraft set. Make sure you gap the plugs to .054 and torque the plugs to 12ft lbs. Modulars like one range cooler than stock so Autolite 103s are optimal. Copper makes better power than platinum but won't last 100k. More like 30k. They are easy to do though so it's not a big deal.
Sent from my VS980 4G using Mustang Evolution mobile app
Spark plug wire diagram Mike V. General Mustang Discussion 5 02-02-2014 11:38 AM
Coil pack and spark plug wire replacement 2000v6stang Pre-2005 V6 Mustang 5 09-01-2013 11:56 AM
spark plug wire. Audicrashdummy 2005-2010 V6 Mustang 7 01-30-2013 12:21 PM
Ford Racing 9mm Spark Plug Wire Problem 95GTease 1979-1995 Mustang GT 3 07-17-2012 03:10 PM
Spark Plug wire Clips RollinonGT 1996-2004 Mustang GT 1 12-12-2011 01:07 PM
11:59 PM
