Anyone ever replace rod bearing with the motor still in the car - Mustang Evolution
Old 05-17-2014, 07:43 PM   #1
WJL
Well i think i may have hammered on her a little harder than i should have. Got a rod knock in Cylinder #6 knocks at start up and above 2500 RPM sounds OK at idle.
I have everything unbolted and going to lift the engine, I have cut a V-notch in a bock of wood and plan to jack it from the damper with a bottle jack and will support it with blocks of wood at the motor mounts. i think if i can get 3" or 4" i can get the oil pan off and pull the rod cap and measure the crank. Here's hoping
I would like to know if anyone has done this successfully ?
WJL is offline   Reply With Quote
Old 05-18-2014, 04:17 AM   #2
I need to stop taking mines uo to 5k =(
Hope it goes well
Sent from my SPH-L710 using Mustang Evolution mobile app
19robby2 is offline   Reply With Quote
Old 05-18-2014, 08:18 AM   #3
1lowGT's Avatar
It's not that hard to pull the motor. It would be easier to pull it.
Replace wheel bearing/hub? FORDuhl6 2011-2014 Mustang GT 10 02-17-2013 01:02 PM
Pinion Bearing or Wheel Bearing? SCCofSV 2005-2010 V6 Mustang 0 09-30-2012 02:43 PM
What would it cost to replace a throwout bearing on a 2004 mustang GT 4.6? makis 1996-2004 Mustang GT 5 12-20-2011 10:20 AM
How long does it take to replace throwout bearing? esra 1996-2004 Mustang GT 1 12-19-2011 09:37 PM
Rod bearing noise? OH NO!!! In2dreamingbig 1996-2004 Mustang GT 12 04-28-2006 12:22 PM
10:23 AM
