MAF upgrade! - Mustang Evolution
Old 05-19-2014, 03:36 PM   #1
mustangmar2001's Avatar
MAF upgrade!
I need to upgrade my mass airflow sensor and don't know what size to upgrade it too... Here are a list of mods I have on the car: 00 GT
Bbk Cold air intake
Bbk 70mm throttle body
Accufab plenum
NGK Iridium spark plugs
Accel coil packs
Typhoon intake manifold
I have a 3.73 gear to be installed soon..
What do you guys consider?
mustangmar2001 is offline   Reply With Quote
Old 05-19-2014, 03:40 PM   #2
Mile high JDF's Avatar
Why do you think you'll need a MAF upgrade? The stock one should handle your mods just fine.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 05-19-2014, 04:21 PM   #3
The mechanic who worked on my car told me that it needed upgraded. So I don't know... Which the car is running a little rich though.
Old 05-19-2014, 04:24 PM   #4
And every since I installed my new intake, the cars idling has been acting up... He also told me to put a new throttle position sensor..
Old 05-19-2014, 04:42 PM   #5
Adogg's Avatar
Doesn't seem to me you need upgraded maf at all.... If your have idling problems after the intake install I would assume your problem is caused by the new intake. Not sure what it could be but I would clean your maf that you have now and check the throttle position censor and iac censor.
Don't hate....... appreciate
Old 05-19-2014, 04:44 PM   #6
Ah so your mechanic doesn't know **** about aftermarket upgrades then or thinks it's like an old 5.0 that needs MAF upgrade when doing injectors. Start with doing an idle relearn and go from there. Did you remove the air screen on your MAF when you installed the CAI?
Old 05-19-2014, 04:54 PM   #7
Adogg's Avatar
^^ +100
Old 05-19-2014, 05:39 PM   #8
Stock MAF is good for more power than the stock rotating assembly can handle. Time to find a new mechanic who does not have his head neck deep.
Old 05-19-2014, 05:56 PM   #9
I actually haven't removed the air screen on the MAF. Glad I asked though..
Old 05-20-2014, 07:14 AM   #10
Another question, Would it be a good idea to upgrade the fuel injectors then? They're stock as well... I was suggested to upgrade them to 24 lbs?
Old 05-20-2014, 07:17 AM   #11
Adogg's Avatar
Are you going to upgrade the maf? And do you have a tuner yet?
Old 05-20-2014, 07:20 AM   #12
I believe I will keep it stock for now and yeah, I have a tuner.
gt40 upper amd lower and maf upgrade! 87blackonblack 1979-1995 Mustang GT 216 08-13-2012 09:23 PM
95 5.0 MAF upgrade to a 80mm 2000 4.6 MAF chatanaka36 1979-1995 Mustang GT 3 07-03-2012 08:57 PM
04:22 PM
