2000 mustang gt - Mustang Evolution
Old 05-20-2014, 12:28 PM   #1
ryank64's Avatar
2000 mustang gt
Hey I got a 2000 mustang gt I put a throttle body and cold air intake in and now she has a hard time speeding up should I get one of those bama tuners
Sent from my Nexus 4 using Mustang Evolution mobile app
ryank64 is offline   Reply With Quote
Old 05-20-2014, 08:08 PM   #2
A tuner of some sort would probably help alot.
2012 Mustang Cyclone, 2002 Mustang GT, 2004 F150 FX4, 1999 Ranger O/R 4x4, 2007 Harley FXDB
jefx is offline   Reply With Quote
Old 05-20-2014, 08:15 PM   #3
Mile high JDF's Avatar
Gotta be a bit more specific than that. Did you upgrade the plenum as well or just the throttlebody?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 05-21-2014, 07:11 AM   #4
daninacan360's Avatar
No matter what you added, a tuner ties all your mods together. Your engine doesn't know what to do with the extra airflow, and a tuner would change your ratios to more accommodate the additional flow
daninacan360 is offline   Reply With Quote
Old 05-21-2014, 12:10 PM   #5
ryank64's Avatar
One more question is it hard to change a throw out barring
Old 05-21-2014, 12:31 PM   #6
A perfect example of the uselessness of a CAI. There's no more air flowing into your engine than before, you've moved the location of the Mass Airflow sensor so now your car needs a tune to accommodate for that...
Id take it off and put the stock air box back on.
You need to remove the transmission to replace the throw out bearing.
Old 05-21-2014, 12:34 PM   #7
ryank64's Avatar
What's a CAI and I'll just get a tune and with the throw out bearing how hard is it to do like should I get a shop to do it if so how much u think its going to cost
Old 05-21-2014, 12:34 PM   #8
Cold Air Intake
Old 05-21-2014, 12:36 PM   #9
ryank64's Avatar
Oo OK makes sense
Old 05-21-2014, 12:44 PM   #10
Throwout bearing requires the whole transmission to come out to replace it. If you are going to do that do the clutch while you are at it and get the flywheel resurfaced. Its not cheap at any rate.
Old 05-21-2014, 12:48 PM   #11
What size is the throttle body that you installed?
To replace the throw out bearing is the same amount of labor to do a clutch replacement so you may look into doing the whole job while you have it apart. If you don't have the proper tools, removing the transmission can be difficult. I don't know exactly how much it would cost to have a shop do the work but I'll take a guess and say around $1000 to do the entire clutch job and probably $600 or $700 for just the throw out bearing.
What's wrong with the bearing? Is it squeaking?
Old 05-21-2014, 12:50 PM   #12
ryank64's Avatar
I just got the clutch replaced but now after a few months my clutch pedal is bouncing around so I was assuming it was my throw out bearing
Old 05-21-2014, 12:57 PM   #13
Bouncing around, huh?
You can feel it through the pedal?
Maybe you should take it back to the shop that did the work and have them look at it...
Old 05-21-2014, 12:57 PM   #14
ryank64's Avatar
78mm its the bbk of America muscle
Old 05-21-2014, 12:58 PM   #15
If you hear a lot of whining coming from the transmission area on deceleration (most noticeable with engine braking) then thats your throwout bearing, make sure it is that before you actually pull the transmission. Speaking of that, mine is practically shot so i can hear that pretty bad lol.
Old 05-21-2014, 12:59 PM   #16
What type of clutch cable do you have?
Old 05-21-2014, 12:59 PM   #17
ryank64's Avatar
Well do u think it could be the thorw out bearing or something eles
Old 05-21-2014, 01:01 PM   #18
Old 05-21-2014, 01:09 PM   #19
Well you have to pull the transmission out, do you think that's hard to do? It was pretty easy for me.
Old 05-21-2014, 01:09 PM   #20
ryank64's Avatar
Probly stock
---------- Post added at 07:09 PM ---------- Previous post was at 07:09 PM ----------
But no clue
Old 05-21-2014, 03:15 PM   #21
ryank64's Avatar
U think it be a table
Old 05-21-2014, 03:16 PM   #22
ryank64's Avatar
Cable
Old 05-21-2014, 07:22 PM   #23
78mm throttle body? on a stock engine?.... thats your problem. That throttle body is for forced induction, not natural aspiration.... its too big. Im pretty sure that 70mm is as large as you want to go without a turbo or supercharger. a 78mm TB will make your car lose power.
I hate to be the bearer of bad news, but the CAI/TB combo you bought is useless on your car. can you return it and get the correct TB?
Old 05-22-2014, 10:16 AM   #24
ryank64's Avatar
I don't think so but I was reading up on it and it said a tuner would fix that and I also called the place and they said a tuner would help
Old 05-22-2014, 10:21 AM   #25
You should not have to tune for bolt ons in a 2V, period. When you did the CAI did you spray the hell out of the filter with the K&N oil because that can foul a MAF sensor like crazy. I'd clean your MAF element and go from there. I've got a CAI/Plenum on my 2V and the tune is stock and it pulls as hard as a stock 2V can.
Old 05-22-2014, 12:13 PM   #26
ryank64's Avatar
2000 mustang gt
What's a maf I'm new to tuning and fixing up cars
Old 05-22-2014, 12:36 PM   #27
Adogg's Avatar
Maf= mass air flow censor
Don't hate....... appreciate
Old 05-22-2014, 05:37 PM   #28
ryank64's Avatar
OK how do I clean it
Old 05-22-2014, 06:49 PM   #29
buy a can of MAF cleaner spray from parts store.
Remove MAF
Spray the wire elements inside the MAF
Reinstall
the wire elements can break if touched, be careful with them
If really dirty, you can use a very fine artist paint brush along with MAF spray to help remove deposits.
Old 05-22-2014, 07:12 PM   #30
ryank64's Avatar
Should I clean NY fliter to
2000 mustang
Would a 2000 v6 maf fit a 2000 gt greenstang41 Pre-2005 V6 Mustang 5 06-30-2013 06:55 PM
2000 mustang :: 2000 Ford mustang kohli412 Member Garages 0 05-02-2013 05:26 PM
2000 V6 :: 2000 Ford Mustang hihosilver Member Garages 0 06-15-2011 12:02 PM
"Mustang" :: 2000 Ford Mustang killacam114 Member Garages 0 06-15-2011 12:01 PM
04:09 PM
