Clutch cable or throw out bearing - Mustang Evolution
Old 05-21-2014, 05:59 PM   #1
ryank64's Avatar
My clutch pedal is bouncing like crazy what would it be
Sent from my Nexus 4 using Mustang Evolution mobile app
ryank64 is offline   Reply With Quote
Old 05-21-2014, 07:00 PM   #2
Mile high JDF's Avatar
Neither. First try the clutch quadrant readjust by pulling the clutch pedal up (towards you) to force it to readjust. If thay doesn't work then do the clutch pedal free play mod (google it) your TOB is fine if it isn't squealing and the cable is fine if it isn't ridiculously stiff.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 05-21-2014, 07:19 PM   #3
ryank64's Avatar
I pulled the pedal to me and it doesn't it again when I push the clutch in
Old 05-21-2014, 07:36 PM   #4
Alright do the free play mod
Old 05-21-2014, 07:45 PM   #5
ryank64's Avatar
OK I'll look into thanks for the help bud
Old 05-21-2014, 07:55 PM   #6
Yeah no problem. The reason the clutch pedal is bouncing is because the TOB is riding on the clutch fingers all the time. The mod is just installing a spring on the cable by the clutch fork to force the fork backwards
Old 05-22-2014, 10:14 AM   #7
ryank64's Avatar
So I gota buy a spring for this
---------- Post added at 04:14 PM ---------- Previous post was at 04:13 PM ----------
Then what just hook it up under the dash there I'm sorry I just can't find a video
---------- Post added at 04:14 PM ---------- Previous post was at 04:14 PM ----------
How much is this mod just wondering
And thanks again for all the help
Old 05-22-2014, 11:36 AM   #8
Do NOT do the free play mod. The TOB is designed to ride on the clutch fingers at all times under light cable tension. Otherwise you are going to be taking the TOB from 0-however many RPM you are going in an instant. It burns up the TOB and is hell on the clutch fingers. I did the free-play mod once before I knew better. Smelled like burning clutch every time I drove the car. I researched more and found out it is a HUGE no-no.
If the pedal is bouncing around then it could be the quadrant or it could be something with the clutch assembly. Like... what EXACTLY is it doing.
Old 05-22-2014, 12:15 PM   #9
ryank64's Avatar
So how would I find out the prob
Old 05-22-2014, 12:20 PM   #10
Well do you have a stock cable or aftermarket? Because aftermarket cables are ALL problematic. Also look under the dash and see what sort of quadrant you have installed or if its OEM. When I got my 98 the previous owner had just throw a random quadrant in there and not shimmed it properly or anything. The pedal feel was terribad. You could also have a broken plastic quadrant.
Like I said describe exactly what it is doing and under what circumstances, if anything makes it better, if anything makes it worse.
Old 05-22-2014, 12:24 PM   #11
ryank64's Avatar
Its just hard when I don't rly no what I'm looking for i pretty sure its a stock cable
Old 05-25-2014, 04:04 PM   #12
ryank64's Avatar
I took some pictures of my quadrant but idk if its OK or what I got to do but this clutch pedal is starting to piss me off so if someone could help that be amazing
ID:	157822   Click image for larger version
ID:	157824   Click image for larger version
ID:	157826   Click image for larger version
ID:	157828   Click image for larger version
chirping noise at idle on clutch,could be throw out bearing? fctwf 1996-2004 Mustang GT 53 06-05-2013 12:33 AM
86 throw out bearing bad? lilrafe87 1979-1995 Mustang GT 101 06-15-2012 01:46 AM
Throw out bearing question jhagan1980 1979-1995 Mustang GT 30 11-27-2011 03:50 PM
Throw Out Bearing? USAF_stang 1996-2004 Mustang GT 9 07-20-2011 01:07 PM
Junk Throw out bearing!!! Rascal Pre-2005 V6 Mustang 16 06-18-2010 03:24 PM
03:34 AM
