help please - Mustang Evolution
Old 05-21-2014, 07:26 PM   #1
samcrored's Avatar
help please
00 gt ..udp..catback ..373 gears and bama tune and shirt shifter ...
18 inch cobra r wheels problem is I get no traction whatsoever 1st 2nd 3rd and sometimes 4th. its a pain it feels dog slow i can feel the rear end swaying all overover thethe place butbut I'mI'm notnot going anyhhere too fast
samcrored is offline   Reply With Quote
Old 05-21-2014, 07:37 PM   #2
Mile high JDF's Avatar
Get some tires and a driver mod
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 05-21-2014, 07:38 PM   #3
Fourth?!!?!?!!!???
Well you're definitely not having a horsepower problem...
Have you checked to make sure that the Trac-lok is working correctly and that both of the rear wheels are spinning? They do wear out, faster than you would think...
What tires do you have on the rear?
Old 05-21-2014, 07:41 PM   #4
samcrored's Avatar
not familiar with trac lock...and there general uhp tires
Old 05-21-2014, 07:43 PM   #5
samcrored's Avatar
ive even had someone behind me and when I get on it the back end sways like hell and im not moving as fast as I think I should be
Old 05-21-2014, 07:46 PM   #6
samcrored's Avatar
I believe they are 373s the owner before me said they were I'm at about 2600rpms in 5th at 60ish
Old 05-21-2014, 07:48 PM   #7
Is there something broken in the rear suspension?
2012 Mustang Cyclone, 2002 Mustang GT, 2004 F150 FX4, 1999 Ranger O/R 4x4, 2007 Harley FXDB
jefx is offline   Reply With Quote
Old 05-21-2014, 07:51 PM   #8
samcrored's Avatar
not to my knowledge...a little squeek sometimes when its cold
---------- Post added at 07:51 PM ---------- Previous post was at 07:50 PM ----------
forgot to mention its lowered 1.5 inch with sr aprings
Old 05-21-2014, 07:52 PM   #9
If something is worn out or broken back there, it could be swaying around under load.
Old 05-21-2014, 08:26 PM   #10
Trac lok is Fords version of a posi traction differential. It has clutches inside of it that wear out. I'd check to make sure that BOTH of the rear wheels are putting power to the ground.
Carefully, Sam...
Old 05-21-2014, 08:41 PM   #11
help please
You sure that you have 3.73s? I'm turning 2500 rpms at 70mph with 4.10s
Old 05-22-2014, 08:19 AM   #12
Site Sponsor
Sponsor
AMWill's Avatar
Something doesn't sound right if you're breaking the tires lose in 4th gear with those few modifications. Even if your tires we dry rotted, worn down, and have seen better days, they should still hook up in 4th gear haha.
Are there any kind of noises coming from the rear end? Does the car have excessive body roll? When your friend is driving behind you, are is he/she sure that both wheels are spinning? Does everything seem to mechanically sound?
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 05-22-2014, 08:24 AM   #13
First, find out what gearing you have back there. Its easy to just spin the tires and mark how many times they go around per 1 revolution of the driveshaft. IE, 1 spin of the driveshaft and a little over 4 tire rotations=4.10s.
Second, get the car in the air and see what is going on back there. Stock suspension components in these cars are barely adequate when new much less 10+ years old.
Third, get a good set of tires on there. Old, bald, dry rotted tires are going to do this although spinning into 4th is not happening with a stock 2V unless you have a diff problem or the tires are literally bald and you are on wet weather.
Old 05-22-2014, 08:25 AM   #14
samcrored's Avatar
I did a quik burnout this morning and there were two tread marks
Old 05-22-2014, 08:27 AM   #15
samcrored's Avatar
only thing I notice is starting off normal..if I dont takeboff quijly thenbthe whole car shakes and feels like the wheels are hop ping around
Old 05-22-2014, 09:01 AM   #16
Site Sponsor
Sponsor
AMWill's Avatar
It sounds like there's some loose components in your suspension. I'd get the car on jack stands as soon as you can and give everything a thorough inspection. It the car is hopping around easily, there could be a few things causing it. One could the rear control arm bushings. Both upper and lower control arms should be thoroughly checked. If they're worn out, that would easily cause a loss of traction!
Shane
Old 05-22-2014, 11:21 AM   #17
samcrored's Avatar
now that I think about it my car sits crooked
Old 05-22-2014, 11:23 AM   #18
You could very well have broken springs or shot bushings or a combo of that back there. I'd get it up on stands asap before something broken back there causes a wreck.
My 92 mustang died please help please wont start HybridTruth93 1979-1995 Mustang GT 2 05-04-2014 03:07 PM
Please help me! Please!! 98StangKid SVT Mustang 0 05-17-2013 09:40 PM
PLEASE, PLEASE HELP!!! Zoe 2005-2010 V6 Mustang 6 03-11-2012 01:19 PM
MT82 Transmission Issue...Please Read and Please HELP DannyDoright 2011-2014 V6 Mustang 5 03-02-2012 08:46 AM
Sold a Car Please, please help!!? booth General Mustang Discussion 9 03-20-2010 09:29 AM
07:58 PM
