Oxygen sensor - Mustang Evolution
Old 05-22-2014, 07:23 PM   #1
Oxygen sensor
I have an 03 mustang gt that had warped heads, so I bought an 01 mustang engine from a salvage yard and put it in. I kept my electrical harness from my 03 engine and transferred it to the 01 engine. I also bought a CAI to put on the engine as well. When I was hooking the CAI up, I noticed I didn't have an oxygen sensor. The car is also starting to run like crap. Could this be because of the o2 sensor?
I'm a young guy wanting to learn and become a mechanic someday. Thank you for all your help
StangGang44 is offline   Reply With Quote
Old 05-22-2014, 07:55 PM   #2
Grimace96's Avatar
I think it just causes it to run too rich without the o2 sensor. I could be wrong though. Could have the opposite effect. I'm still new to this too.
Grimace96 is offline   Reply With Quote
Old 05-22-2014, 08:23 PM   #3
I can smell gas much more now than what I could before. I just don't understand the HP loss though. But I think it is running too rich
Old 05-22-2014, 08:26 PM   #4
Grimace96's Avatar
Yeah. You're rich. Invest in a sensor before you clog your cats and piss off Mother Nature lol.
Old 05-23-2014, 12:53 AM   #5
When you say that you don't have an oxygen sensor do you mean that there is nothing in the hole where the O2 sensor should be?
If that is the case, yes, that will for sure make your car run like crap!
There are four O2 sensors on these cars and I'm assuming that the one that you noticed was an "upstream" O2 sensor... The two upstreams are the critical ones.
Make sure that you plug it in all the way when you install it.
Old 05-23-2014, 08:11 AM   #6
Yes there's a hole that nothing goes in on my CAI that i assume is the o2 sensor. I'll get one of those as soon as possible. Thanks guys!
Old 05-23-2014, 09:52 AM   #7
BigB227's Avatar
Your cold air intake does not have o2 sensors, some CAIs have a hole that's used by earlier mustangs before 2002 I think. if it's what I think your referring to then it's a useless hole for the 03 GTs, plug it up. O2 sensors are in your exhaust (exhaust manifolds and mid pipe) you throwing any codes? The only thing your cold air intake should have is a mass air flow sensor and housing
BigB227 is offline   Reply With Quote
Old 05-23-2014, 09:22 PM   #8
It says the o2 sensors are my problem. That's what the code reads anyways. Another guy said I need to get new cat converters cause mine are clogged. Could this be the problem to why my o2 sensors are reading bad and the car has no hp.
Old 05-23-2014, 09:38 PM   #9
What is the code?
Old 05-23-2014, 09:44 PM   #10
BigB227's Avatar
Well yes you need new upstream O2s but I was saying that your CAI does not contain your oxygen sensors. I might have misunderstood you but I just wanted to clear that up for you. I had the same codes as well and car ran like crap, replaced O2 and BAM just like new
Old 05-23-2014, 09:53 PM   #11
Did I miss something?
If you post the code, OP, it will be easier for us to help you diagnose your problem.
Where is the bank 2 sensor 1 oxygen sensor located? BIG R 2005-2010 Mustang GT 2 10-04-2013 04:46 PM
Signs of a bad oxygen sensor 04machazblue 1979-1995 Mustang GT 33 01-24-2012 04:10 PM
oxygen sensor kickerofdoom Pre-2005 V6 Mustang 5 12-06-2011 07:09 AM
oxygen sensor/ harness sullystang Pre-2005 V6 Mustang 9 02-01-2010 10:15 AM
99 cobra oxygen sensor harness mustang41122 1996-2004 Mustang GT 2 08-21-2009 02:14 PM
04:43 AM
