Torch it? - Mustang Evolution
Old 05-24-2014, 12:03 PM   #1
Grimace96's Avatar
Torch it?
Changing out the ball joint and I don't own air compressed tools. Or electric tools of any sort for that matter. The nut that holds the ball joint on the control arm will just not come off. It was covered with build up and quite rusty. I don't want to break the bolt and end up having to drill it out. Because I don't even own a drill. PB blaster hasn't budged it. I've been reading that I can torch the casting and knock it loose. But is it safe to torch behind the brakes like that? I know they get hot but how hot is too hot?
Grimace96 is offline   Reply With Quote
Old 05-24-2014, 12:18 PM   #2
08AlloyGT's Avatar
How close is the brake line? Could you wrap it with a wet towel to keep it from getting too hot?
08AlloyGT is offline   Reply With Quote
Old 05-24-2014, 12:56 PM   #3
Grimace96's Avatar
Possibly.
Old 05-24-2014, 01:14 PM   #4
Slow4V's Avatar
I usually hit the control arm portion with a big hammer until it drops down.
Old 05-24-2014, 01:17 PM   #5
Grimace96's Avatar
The nut was stuck. Not the bolt.
Old 05-24-2014, 01:22 PM   #6
FullyAutomatic's Avatar
Region: Mexico
I thought you changed this at O'Reily's yesterday ?
FullyAutomatic is offline   Reply With Quote
Old 05-24-2014, 01:26 PM   #7
Try to just heat up the nut and not the ball joint. As the nut expands and contracts from the heat it should break itself loose. Also, don't be afraid to put a long breaker bar on that nut, it's threaded on the metal part of the ball joint and that part will not break.
Old 05-24-2014, 01:27 PM   #8
Tyoung68's Avatar
Heat will be fine just heat the nut
Old 05-24-2014, 01:29 PM   #9
See ^
Great minds think alike...
Old 05-24-2014, 01:45 PM   #10
I was about to say that, then I saw your post
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
Old 05-24-2014, 02:04 PM   #11
I think that she's doing the other side.
Old 05-24-2014, 02:07 PM   #12
samuelsmith's Avatar
You can also get big pliers and squeeze the top half of the ball joint while loosening the nut. I tore up the rubber around the ball joint before getting a good grip. Eventually the pliers will grip metal and the nut will loosen.
Old 05-24-2014, 02:08 PM   #13
Grimace96's Avatar
I'm doing the passenger side now. It was about to do the same.
Old 05-24-2014, 02:09 PM   #14
Grimace96's Avatar
I've already got it guys. Lol. It's done. The ball joint is in. Thanks for all of your help!
Old 05-24-2014, 04:43 PM   #15
Tyoung68's Avatar
Originally Posted by straybullitt View Post
See ^
Ha yeah they do!
For Sale : 2003 Torch Red Mach 1 stampde Mustangs for Sale and Wanted 12 04-18-2012 10:06 AM
Torch Red Paint Code?????? 504 Stang Rida 1996-2004 Mustang GT 3 01-29-2012 08:29 PM
For Sale: 2004 Torch Red V6 04TRV6 Mustangs for Sale and Wanted 0 09-12-2011 06:03 AM
Torch Red Mustang :: 2006 Ford Mustang GrabberBlue10MJ Member Garages 0 06-15-2011 12:01 PM
Side scoop paint issues torch red Dubya11 Mustang Paint, Appearance & Detailing 19 04-18-2011 09:50 AM
08:08 PM
