Are pulleys really worth it? - Mustang Evolution
Old 05-25-2014, 04:01 PM   #1
TheWitness's Avatar
I'm considering getting the bbk pulleys from AM. I'm wondering what kind of increases will I see? Is it worth the $150? My current mods are:
Bbk cai
Tuner
Mac O/R H pipe
Straight pipe exhaust
78mm throttle body and sr spacer
TheWitness is offline   Reply With Quote
Old 05-25-2014, 05:15 PM   #2
Tangtang2.0's Avatar
Steedas are better that's what I've been hearing
Tangtang2.0 is offline   Reply With Quote
Old 05-25-2014, 05:23 PM   #3
PonyBoyV6's Avatar
I'd personally buy steeda as well. Pullies don't really give horsepower, so much as they free up existing horsepower. if you don't have a big sound system in the trunk, you should be good to go.
PonyBoyV6 is offline   Reply With Quote
Old 05-25-2014, 05:25 PM   #4
Steeda
Old 05-25-2014, 07:00 PM   #5
XSlashDashX's Avatar
Steeda x2
Old 05-25-2014, 07:54 PM   #6
Steeda!
royalpurple is offline   Reply With Quote
Old 05-25-2014, 07:58 PM   #7
Eturner's Avatar
I've got BBK Pullies on, and love them!.. Pretty much all they do is help your car rev up faster, getting into your power band a bit quicker!..
Old 05-25-2014, 07:58 PM   #8
Riverdale's Avatar
when i went to buy my 99gt and looked under the hood i saw that the pulleys said steeda.. so go with steeda, for obvious reasons
Riverdale is offline   Reply With Quote
Old 05-26-2014, 08:22 AM   #9
Tiffsobelle's Avatar
I have Steeda UDPs, AND a sound system in the trunk and do fine with charging...but a Capacitor is a must with the sound system.
Tiffsobelle is offline   Reply With Quote
Old 05-26-2014, 02:14 PM   #10
PonyBoyV6's Avatar
I've heard loads of stories of guys with big systems installing UDPs and things start going haywire. Good to know a capacitor will smooth things out in that regard.
Old 05-26-2014, 04:10 PM   #11
Mine's not huge, I'm sure once you really start adding subs and bigger amps, it probably would be a problem. When I first installed my system, I was having some problems, but then I added a cap and it all went away.
I have one 12" Sub and an 800w amp, so once you start getting up there, you'd probably have more problems.
Old 05-27-2014, 01:51 AM   #12
Polar Bear's Avatar
Region: Asia
I recently put the Steeda pullies in my 97 GT and you can feel the difference. Pulls a little harder.
Steve
Polar Bear is offline   Reply With Quote
Old 05-29-2014, 08:09 PM   #13
Speed_Mister's Avatar
Region: Arkansas
I put steeda on my tested me out at the track and knocked off a .1 off my time.
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 05-29-2014, 08:11 PM   #14
Are they hard to install or should I take it to a mechanic?
Old 05-29-2014, 09:27 PM   #15
Region: Arkansas
Got an impact gun?
---------- Post added at 09:27 PM ---------- Previous post was at 09:27 PM ----------
If not you'll need to take it to a shop it'll cost 100$ probably to put them on.
Full Bolt Ons
370rwhp 470rwtq
Old 05-30-2014, 08:23 AM   #16
You don't need an impact gun. Crank pulley is easy because you can just put the motor in gear or do the old breaker bar on the floor trick and bump the starter to let it break itself loose. Water pump is easy, just leave the belt on, loosen the 4 bolts first, take the belt off and remove them the rest of the way.
Alternator should NOT have the pulley changed out. Changing it out does nothing except potentially cause charging issues. I will say though, the 3G alternators are pretty stout. I was running two 12" subs in my old Cobra and BBK aluminum pullies with 0 issues at all. Lights did not dim or flicker or anything when the bass hit, even at idle.
Old 05-30-2014, 06:22 PM   #17
shrek's Avatar
That's funny. You don't strike me as a gentleman who would have two twelves in the trunk
shrek is offline   Reply With Quote
Old 05-30-2014, 06:39 PM   #18
Karbuster's Avatar
I had stock pulleys AND a four banger with 2 twelves on a 1000w amp and the lights only dimmed when it would hit hard while idling
posted from Nexus 5
Using Tapatalk
Karbuster is offline   Reply With Quote
Old 05-30-2014, 09:44 PM   #19
I had a phase at the 22/23 year mark lol. And I got the subs for $150 brand new from a friend. They were Sony XPlods and they were from before wal mart got ahold of them and they went to ****, these were good 4 ohm ones. Paired with that kicker 2 channel amp and some pioneer speakers ran directly off the headunit and it was pretty nice. I would never do it again but I also wasn't bumping Ja or Luda or any of that crap either lol.
omg... music back in the early 2000s... probably should not have existed.
I mean really, really antlers and red noses! Loraco The Bar 18 12-27-2010 02:46 PM
This guy is having a bad day... A really, really bad day JROC The Bar 15 08-16-2007 10:52 PM
How much difference do UD pulleys REALLY make? In2dreamingbig 1996-2004 Mustang GT 34 06-27-2006 11:48 AM
well im really really bored right now Zim The Bar 19 01-06-2004 08:30 PM
im really really bored. Zim The Bar 0 11-17-2003 03:59 AM
06:55 AM
