Knocking or ticking 00 mustang gt - Mustang Evolution
Old 05-28-2014, 12:40 PM   #1
I'm having this problem while driving and I reach at 2000 rpms it sounds like it knocks or tick fast and I can hear it through all gears but when I floor the gas it doesn't do it. It has 108,000 miles 5 speed
Doesn't do it under 2000 rpms
And does it when it's at operating temperature
And it sounds normal at idle
Just put in new oil see if it stop but still the same. (10w 30)
It started doing that when I put my x pipe and slp
The sound I coming from the back of the engine.
Someone help getting frustrated
Murdergt00 is offline   Reply With Quote
Old 05-28-2014, 02:33 PM   #2
You probably have a exhaust leak. You're going to have to go back underneath the car and check all of the conections and re-torque everything.
It's good practice to do that evey time you do any exhaust work.
straybullitt is online now   Reply With Quote
Old 05-28-2014, 02:49 PM   #3
lightning2189's Avatar
Anyone no how much it cost to have retainer bearing done and T 45 transmission not four bolts whole bell housing
lightning2189 is offline   Reply With Quote
Old 05-28-2014, 02:57 PM   #4
Everything seems fine I checked idk if the stock headers have a leak or a bolt lose but it doesn't sound from the header
And idk how to check from the headers
Old 05-28-2014, 03:05 PM   #5
You're going to have to jack the car up and crawl underneath it with the engine running to try to track this down. If it started right after doing the exhaust work, chances are very good that it has something to do with that.
Old 05-28-2014, 03:09 PM   #6
Ty I'll be checking right now
Old 05-28-2014, 03:12 PM   #7
Please use jack stands and be very careful!
1995 3.8 Mustang Knocking Sound <Transmission> Fuel Injector<AOD????? HELP> Jsan105 Pre-2005 V6 Mustang 2 10-26-2011 07:24 PM
95 mustang 3.8L V6 engine knocking 95mustang Pre-2005 V6 Mustang 3 01-21-2011 02:20 PM
ticking/ knocking sound almostxevil Pre-2005 V6 Mustang 16 04-04-2007 06:29 PM
Engine knocking sound (video inside) Brent Pre-2005 V6 Mustang 19 12-02-2004 11:32 PM
Knocking engine Black Panther Pre-2005 V6 Mustang 25 11-02-2004 06:57 PM
08:46 PM
