Engine cuts off - Mustang Evolution
Old 05-29-2014, 06:57 PM   #1
rathke83's Avatar
Region: North Dakota
Engine cuts off
Once my engine warms up the engine dies once I push in the clutch and the rpm get to normal idle. I have changed the fuel filter, tps, and going to change the plugs tomorrow (5-30-14). Is there anything else I should look into doing to keep this from happening again?
Thanks in advance for all your help.
rathke83 is offline   Reply With Quote
Old 05-30-2014, 10:51 AM   #2
Check your air filter and clean the Mass Air Flow sensor while you're at it.
If the idle problem persists after the car is completely tuned up, you will likely have to start looking at the Idle Air Control valve as the possible cause.
Old 05-30-2014, 11:02 AM   #3
rathke83's Avatar
Ok thanks I just went from a jtl cold air to a bbk. Just because no real reason why. But I did hear something about the idle air control. I'll look into that. Thanks again
Old 06-01-2014, 12:32 AM   #4
rathke83's Avatar
I ended up just buying a new gasket for the idle air control valve and clean it out. So far so good but I'll keep you updated once I drive it more. Thanks again
Engine cuts off for 2 seconds then is fine again?? alant007 2005-2010 Mustang GT 0 03-04-2013 07:19 PM
1990 mustang cuts off when put in gear to drive 2.3 engine automatic trans? gillecriosd 2.3 Mustang 0 12-18-2011 12:30 PM
1998 V6 Mustang fuel pump electricity cuts out.. help plz!? 98v6stang101 Pre-2005 V6 Mustang 4 07-07-2008 10:42 PM
Tax Cuts for the rich!!!! Brent The Bar 5 09-23-2004 11:47 PM
Car cuts out in the morning. Black00GT The Bar 6 02-17-2004 09:33 PM
07:10 AM
