a few questions all wrapped into one thread! - Mustang Evolution
Old 05-30-2014, 10:57 PM   #1
zoneo's Avatar
Hey guys,
I've been meaning to post a few different threads so I figured I'd get it all done in one.
1) would there be a way to set up a "battery indicator" to simple tell me when my battery gets low when I have the radio on? Just so I know when to start it and what not. Just one of those "wouldn't it be cool..." Thoughts so let me know what you think!
2) vents.... Sometime when im driving around with either the AC or just regular vents, it will switch to the dash vents regardless of what setting its on, and there's absolutely nothing I can do to change it back ( that I have found at least.
.) and then it will randomly switch back yo the right vent, and there doesn't seem to be anything in common with timing or anything like that. My friend said he thinks its a ford thing and that when the engine gets warmer it'll divert vents to the engine... Which would make sense if the dashboard vents were connected to the engine... (Am I mistaken on that?)
3) I finally replaced the old HU in the mach system, and now I've run into the problem that the new deck pumps a significantly higher amount of voltage per signal so now my factory speakers can't withstand the level and sounds like ****. I have the mach 1000 system in it right now with a pioneer avh-x2500bt. I have two 10" punch II subs with two pioneer and two Polk 5/7-6/9 speakers and phoenixgold 2200 and 4800 amps that I had in my old car... Would it be worth it to just switch them out? Or should I buy new ones? And what about the tweeters?
I know I have more, so I'll just add them as I remember. Thanks guys!!
zoneo is offline   Reply With Quote
Old 05-30-2014, 11:23 PM   #2
Getn off's Avatar
Not sure about Q 2 and 3, but I installed one of these. Progbrains on my bike. I can leave my (1000) leds on until the battery voltage drops to 11.5v then the relay trips and shuts everything off so I can start the bike and drive home...avoiding looking too much like a tool! Works great.
Troy
Amazon.com: Battery Protector (T4): Automotive
Getn off is offline   Reply With Quote
Old 05-31-2014, 05:45 PM   #3
1 - Pointless. A good battery will last several years. If you REALLY want to know then get an aftermarket voltage gauge and you'll know when your volts are getting low for whatever reason.
2 - You have a vacuum leak somewhere. One of the vac hoses going to the HVAC controls or somewhere else is loose or has a small leak.
3 - Completely bypass the garbage mach system. Run a good set of speaker wires if yo have to. This is why I make it a point to buy non-mach cars all other things being equal.
Old 05-31-2014, 09:19 PM   #4
zoneo's Avatar
By bypass do you mean to go ahead and do the swap with the system I already have?
Old 05-31-2014, 09:44 PM   #5
By bypass I mean rip all the garbage Mach crap out and put in your own stuff.
Old 05-31-2014, 11:43 PM   #6
UltArc's Avatar
1) Buy a Scangauge II or Ultra Gauge.
Sent from my XT1049 using Mustang Evolution mobile app
2012 Mustang EPA: 19/29
2012 AeroStang: 40/46
My sponsor, Tokkyo Nutrition, offers 50% off your entire order with the code "PowerHouse"
UltArc is offline   Reply With Quote
Old 06-02-2014, 06:14 PM   #7
zoneo's Avatar
Can anyone tell me where I can find the HVAC control and/or the hoses I need to be checking?
Old 06-02-2014, 06:20 PM   #8
The HVAC control is your climate knobs. Pull the radio bezel and its held on by 4 bolts and a bunch of vac hoses and wires attach to it. Could also be something in the engine bay leaking. Vacuum leaks suck...
Old 06-02-2014, 06:31 PM   #9
zoneo's Avatar
How should I go about checking for leaks? Other than sight
Old 06-02-2014, 06:40 PM   #10
zoneo's Avatar
Okay. So I got the HVAC off the behind the knob is 5 vac hoses red, blue, black, yellow and white. But there is one socket that doesn't have a hose... I can't find an extra hose anywhere... Is that it? Or is that normal?
Old 06-02-2014, 07:20 PM   #11
They should all have hoses on them. Check back in the dash, it could have fallen down in there. At any rate any open port is going to kill your vacuum so that's likely your problem.
Old 06-02-2014, 07:29 PM   #12
zoneo's Avatar
How far could it Go? Any idea what color it is?
Old 06-02-2014, 07:56 PM   #13
zoneo's Avatar
Update: after searching and searching I have found no wire, and no evidence of a wire... Evidence meaning all the wires are taped together and don't appear to be missing any... But the port is obviously missing a wire....
Wrapped Car Slp_loudmouth The Bar 10 06-18-2013 11:50 AM
My 1969 Coupe Wrapped in Vinyl Before and After What do You Think? MG1969Coupe Classic Mustangs 60 04-08-2013 03:18 PM
vinyl wrapped interior sammy13 Mustang Paint, Appearance & Detailing 14 01-27-2013 09:10 PM
Should i get a carbon fiber wrapped center console 1995boss 1979-1995 Mustang GT 31 03-23-2012 03:08 PM
wrapped *****? Rellik The Bar 6 10-27-2003 07:35 PM
07:20 PM
