seriously... - Mustang Evolution
Old 06-04-2014, 02:21 PM   #1
samcrored's Avatar
seriously...
what the hell ...all the way through 4th back end sways wwitwiw spiinIn
samcrored is offline   Reply With Quote
Old 06-04-2014, 02:22 PM   #2
samcrored's Avatar
373 and 275/35/18s
Old 06-04-2014, 02:46 PM   #3
Your clutch must be slipping Sam because your car doesn't have enough power to spin the tires through fourth on dry pavement... Probably not on wet pavement either.
It probably won't even do it in third... On wet pavement.
Old 06-04-2014, 02:48 PM   #4
Screaming Mach's Avatar
Agreed, no way his car is spinning in 4th!
Screaming Mach is offline   Reply With Quote
Old 06-04-2014, 02:55 PM   #5
samcrored's Avatar
how could I narrow it down to the clutch
Old 06-04-2014, 02:57 PM   #6
samcrored's Avatar
but that wouldn't cause the rest to sway..wheni say spin I mean as if the tires are in the air almost
Old 06-04-2014, 03:28 PM   #7
Is it bumpy at all? Live axle plus a 4 link set up that these cars have is complete crap. They have terrible wheel hop.
Old 06-04-2014, 03:31 PM   #8
samcrored's Avatar
very! and just taking off normal when letting the clutch out and giving it has like a normal person it vibrates and shakes car
Old 06-04-2014, 03:34 PM   #9
Is your rear suspension broken?
2012 Mustang Cyclone, 2002 Mustang GT, 2004 F150 FX4, 1999 Ranger O/R 4x4, 2007 Harley FXDB
jefx is offline   Reply With Quote
Old 06-04-2014, 03:35 PM   #10
I don't know what is going on with the rear of your car. As was recommended to you in the previous thread, you need to get underneath the car and inspect it for loose or broken components.
Try to get the car moving from a dead stop in FOURTH gear. If it keeps stalling no matter how much gas that you give it, the clutch is good. If it tries to start moving, and the clutch feels like it's slipping, you're going to need a new clutch.
Old 06-04-2014, 03:42 PM   #11
Laquisha's Avatar
You must of got the rare race car version. 5000whp
Old 06-04-2014, 05:34 PM   #12
samcrored's Avatar
it tried to go in 4th
Old 06-04-2014, 05:37 PM   #13
V6 stang's Avatar
Lol... I could peel out in third on my v6 in wet pavement... GT prolly fourth on wet. 8)
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 06-04-2014, 05:43 PM   #14
Haha
You know what I was trying to say...
Old 06-04-2014, 05:44 PM   #15
V6 stang's Avatar
haha
you know what i was trying to say...
don't say it my car is hella fast bro
Roush Exhaust
Old 06-04-2014, 05:46 PM   #16
Ok. Did it stall right away or did you give it some gas and did it seem like the clutch was slipping and the engine RPM's increased?
Old 06-04-2014, 05:48 PM   #17
Lol
Are you sure that YOUR clutch isn't slipping?
Old 06-04-2014, 05:52 PM   #18
samcrored's Avatar
it didn't stall at all...
Old 06-04-2014, 05:57 PM   #19
I think your clutch is toast.
Does it smell like burning clutch in and around your car?
Burning clutch smells similar to burning brakes...
Old 06-04-2014, 05:59 PM   #20
samcrored's Avatar
not really...the clutches was replaced about 2k miles ago and I've been having the issue about the vibration when taking off and first thought it was clutch chatter
Old 06-04-2014, 06:12 PM   #21
Ok. The car should stall when trying to start from a dead stop in fourth gear. Unless you just tried a 5000 RPM launch.
It's unlikely that you wore out a clutch in 2000 miles but other things can go wrong with them. For instance, the clutch disc can become contaminated with either motor oil or transmission fluid if either of those components develop a leak. Also, the pressure plate can become weak or break altogether.
It sounds like your clutch is slipping but do a little more experimenting to be sure. Or, if this was done by a shop, take it back and have them look at it. If this was done only two months ago, it surely must still be under warranty.
Old 06-04-2014, 07:09 PM   #22
Mile high JDF's Avatar
I can take off in fourth in my car no problem and it's a fairly new clutch. The test I was always told was put it in fifth gear and floor it in a high load situation.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 06-04-2014, 07:12 PM   #23
samcrored's Avatar
i just tried the tests again and it stalled both times..and i did e brake 2nd gear and it died...so im stumped...but either way my rear end is still swaying and it still feels like loss of traction .....as if i was on water
Old 06-04-2014, 07:25 PM   #24
Have you looked at the suspension yet??? If the arse end is swaying around, then you probably have a broken link or springs or something. When you put the rear end under torque it will squat out to the broken side and cause the diff to spin to the side with less load.
Old 06-04-2014, 07:29 PM   #25
GrabberMeBlue's Avatar
Is the body swaying from left to right over the tires like when they break a trailing arm in NASCAR, or do you mean something different when you say swaying around?
2012 Grabber Blue V6 Convertible
1995 Red Trans Am Convertible
1979 Gold Trans Am
GrabberMeBlue is offline   Reply With Quote
Old 06-04-2014, 07:33 PM   #26
That is one torquey engine that you have.
Mine wants to stall from a light if I forget and leave it in second or third.
Old 06-04-2014, 07:37 PM   #27
Now it sounds like your clutch may be fine.
Try the method that JDF recommended, in fifth gear.
Old 06-04-2014, 07:43 PM   #28
Eh it's a combination of the 4.10s, feathering the clutch, and working the throttle. Occasionally I forget that I'm in fourth when I coast to a stop and try to take off in it
Old 06-04-2014, 07:49 PM   #29
While you are under the car inspecting the suspension, also check the inside of your rear wheels for an oily residue, and check the pumpkin for any trace of leakage too.
Old 06-04-2014, 07:51 PM   #30
I hope that you are remembering to put the car in first at the drag strip.
That could be part of the problem...
Old 06-04-2014, 07:55 PM   #31
Haha you got me, I launch in fourth every time
Old 06-05-2014, 10:30 AM   #32
Mfore33's Avatar
Could be rear end gears / trac loc problem
Seriously...... messed up Cajun JungleBoy The Bar 2 08-01-2006 07:22 PM
No, seriously weirdest noise ever... Drunken Ghost Pre-2005 V6 Mustang 9 06-09-2006 04:52 PM
some funny **** right here... seriously, listen to this Zim The Bar 10 04-15-2006 10:51 PM
HOLY CRAP, this is pretty cool!!!.......seriously Kyle The Bar 2 06-16-2005 09:03 PM
I seriously need to stop drinking or something... wiarumas The Bar 25 04-27-2005 02:06 PM
» Members Mustangs
Sally
JR1952
Dubya
Dubya11
Add your Mustang
06:52 AM
