Shutter - Mustang Evolution
Old 06-04-2014, 04:16 PM   #1
ward.r's Avatar
Shutter
Ok so recently my car got a shutter in it when i hit my brakes not all the time but it does happen. I know i needed to changed my tie rod ends but after doing so my car still does it. My brakes and rotors are good nothing looks damaged. What could it be?
Sent from my SAMSUNG-SGH-I537 using Mustang Evolution mobile app
ward.r is offline   Reply With Quote
Old 06-04-2014, 04:25 PM   #2
Check your tires for anything abnormal.
Bad ball joints can cause a shudder, or shimmy...
Probably, the number one cause is warped rotors though.
Old 06-04-2014, 04:33 PM   #3
If its only during braking events, then its probably your brakes. Cheap rotors can go out of whack pretty easily.... who did your last brake job, and what parts did they use?
2012 Mustang Cyclone, 2002 Mustang GT, 2004 F150 FX4, 1999 Ranger O/R 4x4, 2007 Harley FXDB
jefx is offline   Reply With Quote
Old 06-04-2014, 05:58 PM   #4
ward.r's Avatar
My moms friend did it while i was deployed. I think they jus got the stuff at auto zone. Its jus weird that it dont always happen
Old 06-04-2014, 06:32 PM   #5
If it only happens randomly, then it could be a number of things, including something as simple as loose lug nuts. are you getting uneven tire wear?
Old 06-04-2014, 07:55 PM   #6
ward.r's Avatar
Yes thats y i changed the tie rod end. In a month they would destroy the tires so i changed them but about 2 weeks before i did it started to shutter
Old 06-04-2014, 08:11 PM   #7
If you can, try rotating the tires front to back and see if that changes anything.
Old 06-04-2014, 08:23 PM   #8
escottcarp's Avatar
I had that problem on a Taurus. The rotors were warped. Had to use a straight edge to see it.
escottcarp is offline   Reply With Quote
Old 06-04-2014, 08:29 PM   #9
Mile high JDF's Avatar
Does it only happen after the rotors have warmed up?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 06-04-2014, 09:16 PM   #10
Wondering the same thing. Other than warped rotors, a RoadForce wheel balancing machine can help narrow it down.
Shutter... acwatson03 Pre-2005 V6 Mustang 1 05-05-2014 04:44 AM
Clutch Shutter Delta vt 2011-2014 Mustang GT 1 05-24-2012 08:57 AM
Shutter 96CobraConv SVT Mustang 1 12-07-2011 04:56 PM
02 shutter felt in rear axel fpierce General Mustang Discussion 12 08-14-2011 10:28 AM
04:56 PM
