Emergency Brake Light Always On - Mustang Evolution
Old 06-04-2014, 09:13 PM   #1
Can anyone tell me where the emergency brake dashboard light switch is made? Under the car or within the center console?
Thanks. The red light never goes out.
Old 06-04-2014, 09:15 PM   #2
Mile high JDF's Avatar
I have no clue where the switch is located, but that dash light doubles as a low brake fluid indicator as well
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 06-04-2014, 09:18 PM   #3
Red, "Emergency Brake" light?
Old 06-04-2014, 09:20 PM   #4
Far right, second one in (Red).
Old 06-04-2014, 09:27 PM   #5
Yep. I had that issue when I first bought my car, the light would flicker on and off when I was braking. Turned out the fluid level was low.
Old 06-04-2014, 09:39 PM   #6
OK. It never ever goes off. I'll check that out. Thanks.
Old 06-04-2014, 09:45 PM   #7
XSlashDashX's Avatar
Yeah, same happen to my Girlfriends car. The break light would come on randomly and I check the fluid which was low. Filled it up and never came back on.
Old 06-04-2014, 10:20 PM   #8
94gtconvert's Avatar
The parking brake switch is inside the center sonsole on the ratcheting mechanism where the lever bolts to the transmission tunnel. I doubt the brake light is because of the switch though. you should check your brake fluid level, If the brake fluid level is good on both sides of the resovior. If one side is empty you have a broken brake line somewhere.
Sent from my HTCONE using Tapatalk
94gtconvert is offline   Reply With Quote
Old 06-05-2014, 08:18 PM   #9
Thanks guys.
Old 06-05-2014, 08:35 PM   #10
Steve96's Avatar
I had this same question. I filled my with just a touch of fluid. It seems to be a very sensitive sensor at least on mine since it took only about 15% of the small bottle to fill it and shut off the light. I have never had to put any in again and that was a couple years ago.
1996 GT
Old 06-05-2014, 09:27 PM   #11
Keep in mind, brake fluid is hydroscopic so it attracts water. Once you rip the seal off the bottole of brake fluid you have to use what you need and theow the rest out. It attracts water even in a plastic bottole on your shelf in your garage. Last thing you want is moisture in your brake system it can destroy so many components
Old 06-05-2014, 09:31 PM   #12
Steve96's Avatar
Good advice ^^^^ ! I don't have any in my garage for that reason.
1996 GT
Old 06-06-2014, 04:07 PM   #13
BigB227's Avatar
My light recently came on and wouldn't go off, I checked the fluid and it was at te max line so I thought it couldn't be that, changed my brake pads as well and still on, so upon reading this I decided what the hell I'll put a little more fluid in, well that did the trick. Light is now off
BigB227 is offline   Reply With Quote
Old 06-06-2014, 04:09 PM   #14
Really? Fml.
Old 06-06-2014, 04:44 PM   #15
Originally Posted by XSlashDashX View Post
Really? Fml.
Yea dude, flush it out with fresh asap
Old 06-06-2014, 05:00 PM   #16
Wish I knew earlier. Had left over brake fluid from my girlfriends car so I put some in my car. >.>
Old 06-06-2014, 11:01 PM   #17
Thanks, i didnt know that. I do have 4 new Motorcraft Heavy Duty fluid bottles. I'll freshin it up.
Emergency Brake Blakhwk 2005-2010 V6 Mustang 9 09-12-2012 08:33 AM
Emergency Brake Silver Pony 1996-2004 Mustang GT 2 08-08-2012 10:42 PM
Emergency Brake twotone01 Pre-2005 V6 Mustang 2 06-09-2012 07:34 PM
Emergency brake light Ajmt719 Pre-2005 V6 Mustang 12 03-30-2012 09:35 PM
Knob next to emergency brake? Jareds65 Classic Mustangs 8 08-18-2011 09:12 PM
01:23 PM
