fuel rail pressure sensor bad? - Mustang Evolution
Old 06-05-2014, 07:48 PM   #1
So my car shudders when I apply the throttle after cranking it up the first time it sits up over night. What are some symptons of one going bad besides check engine light and fuel in the vac line? I know this is a common problem on boosted cars so someone that has seen this issue can chim in. Tune is fine and ive have changed the 02 sensors, maf, fuel pump, IAT sensor, coolant temp sensors, plugs, COP, and checks for vac leak.
will the FRPS throw a check engine even if it is bad?
I can go out the when the car is acting up and unplug the FRPS and it does GREAT but once I plug it back up it starts acting up with NO CHECK ENGINE LIGHT.
southernstang00 is offline   Reply With Quote
Old 06-05-2014, 11:54 PM   #2
I believe that it should throw a code if it malfunctions.
Hmmm. Tough one. Something must be going on with it, from the result of your "experiment"...
fuel pressure sensor clamp samuelsmith Mustang Parts for Sale and Wanted 0 04-26-2013 11:04 AM
fuel rail sensor samuelsmith Pre-2005 V6 Mustang 0 04-26-2013 10:09 AM
Fuel Pressure Sensor Help Jumpshot 1996-2004 Mustang GT 8 04-08-2013 08:04 PM
fuel line pressure vs rail pressure Sirtat 2005-2010 Mustang GT 2 01-10-2012 05:03 PM
split port swap fuel rail immenukka Pre-2005 V6 Mustang 4 08-09-2007 10:40 PM
02:01 PM
