oil filter gasket? - Mustang Evolution
Old 06-05-2014, 10:11 PM   #1
The_Chech's Avatar
oil filter gasket?
So I think I have a small leak coming from the oil filter adapter/housing thinga mah jig. Looks like it also has a coolant line going to it as well. Any one every had one of these leak on them before? Doesn't look to bad to replace once the oil filter is off just wonder what all might go along on this little fix.
The_Chech is offline   Reply With Quote
Old 06-06-2014, 12:45 AM   #2
Mine leaks.
But only when I over fill the crankcase by a bit...
I have not taken mine off of the Mustang yet, to fix it, but, I have had an oil cooler leak on my F250 and there were two O-rings that needed to be replaced. I imagine that the cooler on the 4.6 is similar...
Old 06-07-2014, 05:23 PM   #3
Roguestang's Avatar
You'll need the gasket, and make sure to torque the bolts back to spec. Obviously, you'll have to drain fluids too....
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 10-25-2014, 06:01 PM   #4
The_Chech's Avatar
So finally got around to getting this done but I cant the torque specs for this any where. Does any one have any clue to how many ft lbs of torque this requires?
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
Old 10-25-2014, 07:09 PM   #5
The_Chech's Avatar
Anybody ?
Old 10-25-2014, 07:14 PM   #6
The oil cooler adapter to block bolts are 15 to 22 ftlbs
The engine oil cooler insert fastener is 43 ftlbs.
Old 10-25-2014, 07:18 PM   #7
The_Chech's Avatar
Awesome thanks
Double gasket problems on oil filter CyStang 2005-2010 Mustang GT 10 04-17-2014 07:28 PM
Oil, Oil Additives, Oil Filters, FACTS robb15033 General Mustang Discussion 2 08-02-2012 12:37 PM
Upper intake plenum gasket and EGR gasket McNassty General Mustang Discussion 1 06-08-2012 11:51 AM
Is a valve gasket the same as a valve cover gasket? birtingr General Mustang Discussion 6 03-15-2010 03:24 AM
cold air k&n filter PN/filter size tire Pre-2005 V6 Mustang 0 12-05-2003 06:37 PM
02:28 AM
