Spun a rod bearing - Mustang Evolution
Old 06-06-2014, 07:19 PM   #1
Spun a rod bearing
I jut had a spun rod bearing on cylinder 8 on my 00 gt and I was wondering if I can take it out on the bottom of the engine.
It barely started ticking
Murdergt00 is offline   Reply With Quote
Old 06-06-2014, 09:14 PM   #2
You'll have to drop the K to get the pan off but once the pan is off you can do it... I honestly would just find a cheap PI pullout from a JY and swap the whole motor though, you never know what that spun bearing did to the crank.
Old 06-06-2014, 09:32 PM   #3
Sorry for the noob question but what you mean drop the k
It just started Doing this ticking noise and I diagnosed it for 2 weeks and everything seemed fine but that piston but who knows how it looks from inside
Old 06-08-2014, 02:52 PM   #4
mattski's Avatar
I pulled my engine and am at the same predicament.
Sent from my LG-D800 using Mustang Evolution mobile app
mattski is offline   Reply With Quote
Old 06-26-2014, 10:01 AM   #5
I pulled the engine out already what else should I replace
I want to do comp cams stage 2 and valve springs
Rod and main bearing 04machazblue 1979-1995 Mustang GT 8 11-24-2012 07:10 PM
Pinion Bearing or Wheel Bearing? SCCofSV 2005-2010 V6 Mustang 0 09-30-2012 02:43 PM
Spun a rod bearing :(...need ideas 98MustangGT 1996-2004 Mustang GT 8 09-20-2012 08:34 PM
Rod bearing Niko Cherad Pre-2005 V6 Mustang 5 11-22-2011 07:50 AM
Rod bearing noise? OH NO!!! In2dreamingbig 1996-2004 Mustang GT 12 04-28-2006 12:22 PM
06:20 PM
