Fuel help - Mustang Evolution
Old 06-07-2014, 10:18 PM   #1
Fuel help
I am having trouble with my car getting fuel. Its a 99 gt.
Car started about two weeks ago and as soon as i went to back out of my driveway i tapped the gas and it died like it wasnt getting fuel. If i let it sit for say 3 to 4 hours it will start back up but do the same thing. Today i replaced the fuel pump and fuel filter and still having same problem. Checked the intertia switch in the trunk been reading a lot about it and that doesnt seem to be the problem. Checked the voltage to the power supply right behind the tank and it seems to have 12 volts on it. I couldnt head the pump priming before i changed it and still cant hear it priming after i changed it. the old one still works checked it when i took it out. anyone got any ideas?
mrmustang99gt is offline   Reply With Quote
Old 06-08-2014, 08:40 AM   #2
I had an old Bronco II that did that when I was a kid. I didnt know how to fix it myself. My Grandpa was able to fix it for me, but I wasnt there when he did it. He told me the problem was a bad fusible link.
Im not sure where the fusible link was located, but I'm guessing it was in line to the pump somewhere and easy to overlook.
Not sure if this info will help you.
2012 Mustang Cyclone, 2002 Mustang GT, 2004 F150 FX4, 1999 Ranger O/R 4x4, 2007 Harley FXDB
jefx is offline   Reply With Quote
Old 06-08-2014, 04:47 PM   #3
Its got power to it im just not able to hear it priming up and it will start but 0 throttle response. It just dies.
Old 06-08-2014, 06:14 PM   #4
Found out today its not getting ground. Does the ground in that wiring harness ground just the fuel pump or does it work as the ground for other things as well?
Old 06-08-2014, 06:20 PM   #5
ColeJohnson's Avatar
The pump has it's own power and ground.
2016 Comp Orange GT (current)
need help with custom fuel rails, fittings, fuel pressure gauge tire Pre-2005 V6 Mustang 2 07-13-2015 03:32 PM
Replacing stock fuel door with stock fuel door...help? MarshallYoung 2005-2010 V6 Mustang 13 07-23-2012 11:23 PM
Pruchased my Fuel Injectors and Fuel pump today Brent Pictures and Videos 36 12-14-2010 03:22 PM
Help help- fuel pump-help! The Darkside Pre-2005 V6 Mustang 26 05-08-2009 01:45 PM
19LB Fuel Injectors; 190-255LPH Walbro Fuel Pump Brent Mustang Parts for Sale and Wanted 5 05-11-2005 11:04 PM
05:02 AM
