2000 GT rebuild - Mustang Evolution
Old 06-08-2014, 02:49 PM   #1
mattski's Avatar
2000 GT rebuild
Okay so I pulled my motor after it lost 90% of compression in cylinder 3. So I am in the process of rebuilding it and I really don't feel like pulling the heads off to pull the pistons through. Would it be easier to pull the crank out and just pull them out through the bottom or should I just embrace the suck and pull the heads?
Any advice helps
Sent from my LG-D800 using Mustang Evolution mobile app
mattski is offline   Reply With Quote
Old 06-08-2014, 03:02 PM   #2
You might be able to get it out that way, but you'll have an EXTREMELY difficult time getting the piston and rings back in that way.
Be one with the "suck"...
Old 06-08-2014, 03:24 PM   #3
mattski's Avatar
Well I'm trying to pull the crankshaft and i can't find anything on line about pulling the crank. Only on taking off the pulley.
Old 06-08-2014, 03:44 PM   #4
You should have a repair manual when doing this sort of work.
If you're going to do this, you should do it correctly or else you'll be setting yourself up for a lot of frustration down the road.
I know that the heads look like a b!tch but would you rather do the head gaskets now while the engine is out of the car? Or, possibly, 6 months from now, bending over a fender to do the work?
There are 6 bolts securing each of the main caps to the block. Four are right there on the cap and two screw in horizontally on either side from the outside of the engine block.
Those cap bolts are NOT reusable. You need to buy new ones when you put it back together... Same thing with the head bolts.
Old 06-08-2014, 04:56 PM   #5
mattski's Avatar
Well I don't plan on keeping the car very long after I get it done (dick move I know)
Old 06-08-2014, 05:10 PM   #6
Lol
In that case, it may be cheaper and easier to just find a used, running engine to swap in and be done with it.
Old 06-08-2014, 05:24 PM   #7
mattski's Avatar
Junkyard wants about 400 for a motor and there's no guarantee that it runs. But I'm probably just going to nut up and shut up and pull the heads
Old 06-08-2014, 05:35 PM   #8
Do you have any suspicions as to why that cylinder has lost compression?
Old 06-08-2014, 06:10 PM   #9
mattski's Avatar
Wet and dry compression test confirmed it
---------- Post added at 12:10 AM ---------- Previous post was at 12:10 AM ----------
But as to why I have no idea
Old 06-08-2014, 06:24 PM   #10
What were the results of the wet test? Did it raise the compression reading or did it remain the same?
Old 06-08-2014, 07:42 PM   #11
mattski's Avatar
Went up to about 35psi and dry test was at 10psi
Old 06-08-2014, 07:54 PM   #12
Hmmm.
This is probably something related to the head or head gasket.
Well, keep us posted what you find...
Old 06-09-2014, 05:25 AM   #13
V6 stang's Avatar
How many miles does it have on it?
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 06-09-2014, 07:34 AM   #14
mattski's Avatar
77xxx not sure on the exact number
Old 06-09-2014, 07:41 AM   #15
V6 stang's Avatar
Wow lol that leaves me discouraged about my 120k engine O.o
Roush Exhaust
Old 06-09-2014, 05:05 PM   #16
mattski's Avatar
Supercharger and I absolutely hate being passed so yea. Plus every one thinks hey a mustang I'm gonna pass it because it's slow and they always seem surprised that they get smoked
Old 06-09-2014, 11:06 PM   #17
mattski's Avatar
Sooo instead of trying to work them out of the bottom I took the heads off. Only to find some not so surprising results
Old 06-09-2014, 11:14 PM   #18
YIKES!!!
You never mentioned a supercharger.
Lol. Those cast pistons really are the weak point.
So what HP is that engine tuned to?
Old 06-10-2014, 05:56 AM   #19
Yeah that'd do it...
I would honestly just find a running PI motor and swap it and call it good if it was me. Will probably be cheaper in the end anyway. Some places will guarantee them to run, you just have to call around.
Old 06-10-2014, 07:09 AM   #20
mattski's Avatar
Well I bought pistons connecting rods and everything so a rebuild is in place
Would a 2000 v6 maf fit a 2000 gt greenstang41 Pre-2005 V6 Mustang 5 06-30-2013 06:55 PM
2000 mustang :: 2000 Ford mustang kohli412 Member Garages 0 05-02-2013 05:26 PM
rebuild of a recent rebuild Black99Snake SVT Mustang 12 08-20-2011 05:24 PM
2000 V6 :: 2000 Ford Mustang hihosilver Member Garages 0 06-15-2011 12:02 PM
donor rebuild vs current engine rebuild cash05_mustang Pre-2005 V6 Mustang 2 07-01-2006 01:09 PM
04:33 AM
