Going from auto to stick - Mustang Evolution
Old 06-08-2014, 03:31 PM   #1
freethrow36's Avatar
Hey guys just wondering how I could switch my 02 gt from auto to stick... i legit want to make it to a stick shift with a shirt shifter. How much would it cost?? Any ideas??
Sent from my SM-G900T using Mustang Evolution mobile app
freethrow36 is offline   Reply With Quote
Old 06-08-2014, 05:36 PM   #2
Doing the work yourself? Either way is going to probably cost a grand or so, that's with getting the trans (cost will depend on what you go with). You'll also need an ecu harness from a 5spd as well I believe.
It's been done before, try Google searching.
Old 06-09-2014, 07:57 PM   #3
Its all over google. I'd j-mod your 4R and throw a good aftermarket stall converter in there and it'll be quicker in the 1/4 than if you converted it.
Otherwise yeah around $500-$1k in parts plus another $1k or so for a rebuilt trans.
Old 06-16-2014, 04:43 AM   #4
03fastblack's Avatar
It's an easy swap but it will set you back a grand. I just did the swap. It's easy to do. Had my auto side turned off on the Ecu so you don't need a new one. You'll need a new pedal assembly, clutch cable, flywheel, flywheel bolts (auto bolts are shorter), clutch, trans of course, clutch fork, trans mount, trans yoke, a new drive shaft is not necessary.
03fastblack is offline   Reply With Quote
Old 06-16-2014, 06:12 AM   #5
It'll set you back a grand if you get the trans used. In my experience, it is a crapshoot with a used T-45 and especially a used 3650. You can pick up a brand new 3650 for $1060 shipped to your door and then all the other swap parts to do it right...
-Resurfaced stock flywheel $100
-Clutch $180
-Shifter $100 used for a Tri-Ax
-Pedal assy is probably $25-$50 out of a JY
-Bolts $20
-New transmount $100
-Clutch cable/quadrant/firewall adjuster $160
-Fork/TOB $75
-Yoke $25
Then whatever tuning the ECU costs or get another ECU for $100 but you'll have to have PATS turned off via a tuner as well.
For 1/3 the price you could j-mod and put a nice Freakshow converter in the auto which will probably pick up a good half a second or more in the 1/4 for a bolt on NA 2V with 4.10s.
Old 06-16-2014, 11:36 AM   #6
I hate the way the mustangs shifters.r.. there long and ugly.. can I but a real short shifter that will look nice??
Old 06-16-2014, 11:38 AM   #7
That's in the top shift lever bolt holes. If I lower it down to the bottom two holes its goes about 1" lower and shorter looking. I like it how it is but I might move it down just to see.
Old 06-16-2014, 02:06 PM   #8
I have the steeda Tri ax I keep it on the highest most setting don't like the lower one
'11+ Auto or Stick? Sanguin 2011-2014 V6 Mustang 99 07-14-2012 01:25 PM
STICK OR AUTO?? 13stang 2011-2014 Mustang GT 175 05-25-2012 11:54 PM
Auto to stick - engine internal balance? FXDWG11bm 1996-2004 Mustang GT 6 01-01-2012 09:48 PM
Stick or Auto for the v6 BulletWalker Pre-2005 V6 Mustang 12 03-19-2008 06:00 PM
swiching a 95 from auto to stick. what do i need? wadman 1979-1995 Mustang GT 4 02-17-2008 07:28 PM
01:31 PM
