Best cam for bone stock 99 gt 4.6 - Mustang Evolution
Old 06-10-2014, 11:46 AM   #1
diego23's Avatar
Hi im wonderin whats the biggest cam i can put to my bone stock 99 gt i want it to sound alittle mean n loud
diego23 is offline   Reply With Quote
Old 06-10-2014, 11:48 AM   #2
Most stage 2 cams like Comp Cams, HiTech, CMS, Crower ect. are the biggest you can go. Remember that the cams will bring the power up into the rpms higher so you will need better gears to compensate for the low end loss.
Old 06-10-2014, 12:18 PM   #3
diego23's Avatar
So i would need a higher gears like 350 or 373s. N by installin a new cam i wouldnt have to change anything else other then the gears??
Old 06-10-2014, 12:22 PM   #4
Ideally you will want 3.73s, then for the cams (remember your motor has 2 of them), you will ideally want adjustable cam gears so you can degree them, and you will also want to replace the valve springs.
Old 06-10-2014, 01:39 PM   #5
You'll probably need a dyno tune, as well, for any cams that have a healthy sounding idle, anyway.
Old 06-10-2014, 02:10 PM   #6
shrek's Avatar
Houston performance 292
Also what everyone else said. A nice stage 2 cam will probably suffice. But "stages" are different for every company so your mileage may vary
shrek is offline   Reply With Quote
Old 06-10-2014, 07:33 PM   #7
diego23's Avatar
Is their any cam err so where i wouldnt need to change err upgrade anything?? Just want it to sound cammed but i dont wanna have to upgrade anything yet or whats the best rout for me to go to start fixin my stock 99 gt all i have for now is a k&n cold air intake n thats it....
Old 06-10-2014, 07:51 PM   #8
toneman's Avatar
I have every bolt on you can get on my 99 Gt. I went with 3.73 gears on a 5 speed trans and love it. Crower Stage 2 cams were added and then tuned. It put down 295 RWHP and 305 foot pounds of torque. I'm happy with the way it runs.
toneman is offline   Reply With Quote
Old 06-10-2014, 07:57 PM   #9
diego23's Avatar
Dam i bet man thats what i wanna do wit mine but im a starter n i wanna be guided the right way its auto i kno their isnt much to do to automatics but i wanna make it as fast as i can i work at advance auto parts so im tryin to learn as much as i can. Just seein guys wit mustangs on the street motivates me on fixin mine
Old 06-11-2014, 10:44 AM   #10
Cushman stage 2 NA cams.
Will require a dyno tune
TFS adjustable crank gears
Degree service
New valve springs
And there is a ton you can do to the auto. J-mod it with a good aftermarket converter and it will be faster than it would be at the 1/4 track if it had a stick.
Old 06-11-2014, 11:03 AM   #11
Degree service
New valve springs
Why Cushman?
Old 06-11-2014, 11:06 AM   #12
Because Cushman has proven over and over again to get the best results.
Also, I missed the part about the car being bone stock. Cams are going to suck on a bone stock car. Needs bolt ons and supporting mods. Cams should be the last thing.
Old 06-11-2014, 11:12 AM   #13
I was just looking at them. Even the stage 1 seem kind of aggressive. I have to leave the stock gears in for my class, or 3.55's. I guess that I need to do more comparisons of all the specs...
Old 06-11-2014, 03:39 PM   #14
diego23's Avatar
Where would i be able to buy that cam at n prices for intallation plz
Old 06-11-2014, 04:45 PM   #15
Every shop is different, call around.
Old 06-12-2014, 09:59 PM   #16
toneman's Avatar
Diego23, what state are you in? I'm in Michigan. I went to Alternative Auto in the city of Chesterfield to have all the work done on my car. Very happy with his work. You can check them out at..www.alternativeauto.com
02 V6 Mustang bone stock P0316 and P0302 codes-refuses to be fixed cessnadriver Pre-2005 V6 Mustang 45 10-04-2013 04:18 PM
bone stock 5.0 new personal best BUSHGUTS At the Track 32 04-29-2013 09:55 AM
Boss 302 goes 11.70's Bone stock w/slicks stampde General Mustang Discussion 7 03-29-2011 05:47 PM
2011 3.7 1/8th mile BONE STOCK AUTO omahamustang Pre-2005 V6 Mustang 7 10-09-2010 07:12 PM
Proud to Announce: 13.43@102mph BONE STOCK! doodad General Mustang Discussion 17 03-02-2007 08:39 AM
09:45 AM
