Headlight Bulb?? - Mustang Evolution
Old 06-10-2014, 07:25 PM   #1
john.petr0's Avatar
Headlight Bulb??
what kind of headlight and foglight combos are you guys running that are not HID. looking for something better than stock
john.petr0 is offline   Reply With Quote
Old 06-11-2014, 07:20 AM   #2
cobrah's Avatar
I've tried a few different bulbs myself ranging from slyvania to LED but I recommend bucking up and buying the HID kit instead of messing around
cobrah is offline   Reply With Quote
Old 06-11-2014, 09:00 AM   #3
I'd just put a better set of bulbs in and re-aim your housings if you don't want to do HIDs. OSRAM (not Sylvania) Silverstars or Philips Xtreme bulbs. Most of the "super bright omfg" bulbs like sylvania silverstars, philips crystalvision, raxiom whatevers are gimmick lights that make you think they are brighter with white light achieved with a blue film on the bulb. Blue film on the bulb actually lowers the overall lumen output.
For fogs I run Nokya Hyper Yellow bulbs. Yellow light is actually the range most pleasing to the eye and will allow you to see best in fog/rain conditions when you need them. They do not need to be on other than in those conditions so being functional is more important than being as bright as possible.
Now if you ever DID want to do HIDs, you should get some projectors or do a HID Retrofit which puts an OEM style projector into your reflector housing. It isn't cheap but its the best way. I personally have a high quality HID kit in a set of DEPO projectors.
I hope you are talking about a HID kit in a good projector or a HID retrofit. HIDs in reflector housings glare like crazy and turn you into a hazard on the road to all incoming traffic. Even the shielded HID "R" (reflector) bulbs that everyone always touts are only designed for HID R specific housings which Mustang reflectors are not.
Old 06-11-2014, 03:07 PM   #4
cobrah's Avatar
Old 06-12-2014, 12:40 AM   #5
GHO5T5NIPER's Avatar
I just put in new headlights with Philips xtreme vision like Scotty said and they are bright as hell. People on the highway sometimes flash their lights at me now to signal that my brights are on and then I give them a quick flash of my actual high beams haha. A bit of a pain for other drivers but sure lights up the ditches better
GHO5T5NIPER is offline   Reply With Quote
Old 06-12-2014, 03:28 AM   #6
bucko's Avatar
Sylvania Silverstars have a hue on the glass, but put out a much brighter white "usable" light over the stock bulb. They say they burn out quicker than stock bulbs, but after two years, mine are still glowing. They are pricey though over the price of standard bulbs. I will however check out the OSRAM Sylvania when these burn out.
I do a lot of early morning highway driving, and catch fog during those times. The yellow fog lights are indeed the better light for cutting through fog, and the lower the lights are parallel to the ground, the better. It amazes me to see folks place a bright white light in the fogs, as this will impeed getting useful light through foggy conditions. The light bounces off the water particles, and produces a glare to the driver. A yellow light is far better, but I guess "coolness" is affected, and therefore not acceptable to most.
Old 06-12-2014, 08:23 AM   #7
I'd suggest reading this article, it might change your mind about the Silverstars. I used to think they were the **** too until I got a legit good bulb in my old stock housings and the Sylvanias don't even deserve to be mentioned in the same breath as my HIR halogens that are in my current DEPOs.
Cliff's notes is that the Sylvanias are actually dimmer than a good OEM bulb.
Edit: Found an old post I made. A is a blue tinted Silverstar bulb. B is a stock yellow halogen and C is a HIR.
ID:	159103   Click image for larger version
Headlight bulb size robin_gt 1996-2004 Mustang GT 3 01-30-2014 05:03 PM
headlight bulb replacement Joe_Roma5 2005-2010 V6 Mustang 1 12-12-2012 03:43 AM
Headlight bulb watts jdavis96gt 1996-2004 Mustang GT 9 12-06-2012 01:15 PM
Headlight & foglight bulb size anthonyrc618 2005-2010 Mustang GT 1 07-29-2012 05:54 PM
How many 232er's does it take to change a light bulb? fast64 The Bar 9 09-02-2003 10:50 PM
10:05 AM
