2004 mustang gt - Mustang Evolution
Old 06-11-2014, 06:25 PM   #1
rich sbarra's Avatar
2004 mustang gt
Hey can anyone help me I have a problem that 2004 mustang gt has a problem that it doesn't go pass 4500 rpms when floored if u back off the pedal it goes pass 4500 anyone have any ideas
rich sbarra is offline   Reply With Quote
Old 06-11-2014, 07:06 PM   #2
I assume that there is no check engine light and no codes.
Does it feel like it's stumbling or running out of fuel when at wide open throttle?
Old 06-11-2014, 07:08 PM   #3
Yah no check engine light but yah it does feel like it is losing fuel
Old 06-11-2014, 07:10 PM   #4
Fuel pump?
Old 06-11-2014, 07:10 PM   #5
Change your fuel filter and if that doesn't help you'll need to do a fuel pressure test.
Old 06-11-2014, 07:10 PM   #6
I changed the filter
Old 06-11-2014, 07:12 PM   #7
Originally Posted by rich sbarra View Post
Fuel pump?
Possibly
Check the pressure first though...
Old 06-11-2014, 07:14 PM   #8
Ok thanks
---------- Post added at 01:14 AM ---------- Previous post was at 01:13 AM ----------
How high should the fuel pressure be
Old 06-11-2014, 07:19 PM   #9
Black99Snake's Avatar
You put the filter in the right direction of flow?
Sent from my SM-G900P using Mustang Evolution mobile app
1999 Cobra black with medium parchment interiorJLT CAI, RWR motorsports tune, Pacesetter Longtubes, o/r xpipe w/cutouts, Flowmaster Super 44s, built t56, Kevlar clutch, Nitto NT05R, Ford Racing 4.10 gears, MMR 900 rotating assembly, vortech v3 si, twin aeromotive 340s, aeroquip lines, 80lbs injectors
Black99Snake is offline   Reply With Quote
Old 06-11-2014, 07:28 PM   #10
35-55 psi
The system should be able to hold pressure for five minutes without losing more than 5psi.
Old 06-11-2014, 07:29 PM   #11
Ok
Old 06-11-2014, 07:34 PM   #12
Ok
Old 06-11-2014, 08:07 PM   #13
Clogged cats(s)
2012 Mustang Cyclone, 2002 Mustang GT, 2004 F150 FX4, 1999 Ranger O/R 4x4, 2007 Harley FXDB
jefx is offline   Reply With Quote
Old 06-11-2014, 08:10 PM   #14
The_Chech's Avatar
Air filter maybe? Couldn't get my 98 4Runner over like 3k rpm when it got clogged from squirrels and there little fun nests in the air box
The_Chech is offline   Reply With Quote
Old 06-11-2014, 08:12 PM   #15
Maybe I'll try cleaning it but I do think I have a fuel problem I bought my car from a dealer and it did sit awhile I had to get a new fuel filter and lines where clean so I might need a fuel pump
Old 06-11-2014, 08:15 PM   #16
My old 01 Monte Carlo wouldnt rev over 4k rpm at one time.... started fine, idled fine, just wouldnt rev out. It stumbled and almost stalled when it got up there... ended up being a clogged cat. Also no CEL.
Old 06-11-2014, 08:18 PM   #17
A bad pump would likely effect more than just a particular rpm range. Hate to see you replace it for no reason.
Old 06-11-2014, 08:19 PM   #18
Yah idk I'll have my mechanic look at it I might have a clogged fuel injected
Old 06-11-2014, 08:31 PM   #19
04beautyGT's Avatar
Is it an automatic or manual? It may be a loose or defective throttle position switch if it's an automatic. I would check it especially it you have changed the throttle body or anything.
04beautyGT is offline   Reply With Quote
Old 06-11-2014, 08:31 PM   #20
It's a manual
2004 mustang
2004 mach 1 vs. 2004 svt cobra Michaelgranlund 1996-2004 Mustang GT 32 03-08-2013 07:19 PM
Mustang #4 (SOLD) :: 2004 Ford Mustang GT 5 Speed SNK3BTE04 Member Garages 0 03-13-2012 10:41 AM
"Venessa" Mustang #5 :: 2004 Ford Mustang Cobra SVT SNK3BTE04 Member Garages 0 03-10-2012 05:55 AM
What is the differnce between a 2004 mustang svt and a 2004 mustang gt? skeet General Mustang Discussion 3 12-13-2011 09:53 AM
04:28 PM
