Front Brakes - Mustang Evolution
Old 06-12-2014, 09:02 AM   #1
Michael.s.king's Avatar
Region: Maine
Front Brakes
Getting ready to do my front brakes today after work. Just doin rotors pads and guide pins.
Any tips or advice to make this easier before I get into it?
Michael.s.king is offline   Reply With Quote
Old 06-12-2014, 12:10 PM   #2
fomoco4life's Avatar
There is a tool you'll need to compress the calipers (they screw open/closed) I believe it's only needed for front brakes , $5 at parts store, the rest is pretty straight forward
Old 06-12-2014, 12:14 PM   #3
Region: Maine
Oh, I thought this was only needed for the rear brakes?
Old 06-12-2014, 12:19 PM   #4
The fronts don't screw in, you can get by with a large C clamp and one of the old brake pads if you want, or there is a tool to push the front pistons back in.
Sent from my SM-N900P using Tapatalk
2004 GT - Bama SCT Tuner - Pypes catted X-Pipe - Pypes Violator Catback
- Comp XE270AH - DIY Sequential Turn Signals in the works!
ltdan is offline   Reply With Quote
Old 06-12-2014, 04:27 PM   #5
Lol, the rear brakes screw in, this is the way pretty much every rear brake works. I just use needle nose pliers and a lot of 4 letter words to spin them and its always fine .
Fronts are easier than the rears but you need to make sure you have a good 18" or longer breaker bar to get the goddamn caliper bolts off.
To compress the calipers themselves I just use a big set of channel locks. I also always do a power bleed when I'm done. Bought a Motive 1 person bleeder kit and it works great for this, you just have to make sure you get it with the 3 prong Ford specific cap since the universal caps are all junk.
Old 06-12-2014, 04:36 PM   #6
Oh ya duh, bass akwards....c clamp front, screw in back...lol
BRAKES front & rear chris7869 Pre-2005 V6 Mustang 1 09-08-2007 07:16 PM
front brakes 96bluegt 1996-2004 Mustang GT 2 05-21-2007 08:20 PM
stock front brakes, cobra rears...bad? tedness Pre-2005 V6 Mustang 6 10-07-2005 06:23 PM
Cobra Front Brakes, MM Rack Bushings, and PICTURES added... Rick0636 Pre-2005 V6 Mustang 32 03-29-2004 08:46 AM
Cobra front brakes, MM rack bushings, and Pics ADDED Rick0636 Pre-2005 V6 Mustang 8 03-28-2004 09:39 PM
10:07 PM
