Fog light problem - Mustang Evolution
Old 06-12-2014, 11:24 AM   #1
Jsansom's Avatar
Fog light problem
I had hids in my fog lights. One night I was drivin home and it was raining. Well now the fog lights don't work. I took the hids out and out regular bulbs in and still don't work.. Any ideas?
Jsansom is offline   Reply With Quote
Old 06-12-2014, 06:18 PM   #2
EvilGT's Avatar
Did you have a relay for the hids? I'm not sure if you need it or not but my dad had hid fogs and they kept going out. Put a relay in and now they work perfectly.
EvilGT is offline   Reply With Quote
Old 06-12-2014, 06:31 PM   #3
Jsansom's Avatar
Yea had that.. But the hids aren't the problem. Even with regular bulbs in there the fogs still don't work
Old 06-12-2014, 06:41 PM   #4
EvilGT's Avatar
Did you check the fuse?
Old 06-12-2014, 06:42 PM   #5
Jsansom's Avatar
I checked the big fuse under the hood.. But idk how to tell if that one is bad.. And is there another one somewhere
else?
Old 06-12-2014, 06:49 PM   #6
EvilGT's Avatar
The only thing I can think of since both fogs are off is either a blow relay/fuse.
Old 06-12-2014, 06:50 PM   #7
Jsansom's Avatar
Yea. Alright I'll look for another fuse. And see what happens.
Old 06-12-2014, 11:16 PM   #8
phillip433's Avatar
Let us know because I have the same problem.
phillip433 is offline   Reply With Quote
Old 06-13-2014, 03:19 AM   #9
bucko's Avatar
Buy a multimeter or at the very least, a test probe (looks like a screwdriver with a wire at one end, and a built in 12 volt light). These can be had for a few dollars at any auto parts store. You clip the probes wire to ground, then use it's tip to check each point of the wiring; if the light glows, you have power.
In your case, you'd start at the fuse point to see if there's power at the fuse; at one point of the fuse socket, there'd be power, and the probe would lite. If the fuse is blown, the other side would not lite the probe. For a relay, you'd need to know how a relay works: one point of the relay is the incoming power source, one point is ground, one source is the "trigger power" (such as a light switch) that energizes the relay, and one point is power out to the fogs.
You should however be able to "see" if a fuse is blown, unless you are using some sort of non stock fuse....
Old 06-13-2014, 01:41 PM   #10
Jrh2592's Avatar
There are two relays under the hood for the fog lights. One controls the foglights (relay position 3 I believe) and the other is the relay to turn your foglights off when you switch your high beams on (relay position 1) if either of these are bad, then your fogs wont work. I definitely agree with putting a multimeter to them to see if theyre bad or not. Refer to your owners manual in the roadside emergencies section just to confirm the relay positions.
Jrh2592 is offline   Reply With Quote
parking light / fog light mod 1994-2000 FullyAutomatic 1996-2004 Mustang GT 3 04-09-2014 10:29 AM
Can i have both grill fog lights and lower fog lights working at the same time? servs 2011-2014 V6 Mustang 3 03-31-2014 05:35 AM
fog light problem 1987mustanglx50 1979-1995 Mustang GT 6 09-01-2012 06:53 PM
Fog Light problem. runvsofthisbull Pre-2005 V6 Mustang 12 01-23-2008 06:07 AM
Swap my Cobra fog lights for your GT fog lights TheDad Mustang Parts for Sale and Wanted 1 01-19-2006 01:01 PM
03:44 PM
