Caster camber plates - Mustang Evolution
Old 06-12-2014, 05:33 PM   #1
TheWitness's Avatar
Okay guys, I'm thinking about lowering my car 2" up front and 1.8" in the rear. If I end up not getting caster camber plates how badly will my tires wear? Also are there any other repercussions?
TheWitness is offline   Reply With Quote
Old 06-12-2014, 06:33 PM   #2
Your entire frontend alignment will be off and you'll **** up your tires in pretty short order.
If you are going to lower your car, CC plates are a required item. Either do it right/safely or don't do it at all.
Old 06-12-2014, 06:34 PM   #3
My Mach 1 is lowered about that much. No CC plates at the moment. I put brand new tires on one year ago and the wear on the inside is pretty noticeable. I also only put about 8k miles on the cat per year.
I actually just noticed the wear doing and oil change. Maximum Motor sports CC plates on order.
If you're gonna lower it and value your tires invest in the cc plates too.
I notice handling/driving issues like when on the interstate changing lanes, I can feel the steering wheel pull going over even the slightest uneven pavement.
I moved to San Diego last month and the lane divider stripes have these freaking bumps in them. Steering pulls going over them as well.
Old 06-12-2014, 08:06 PM   #4
TheWitness's Avatar
So if I go any lower than I currently am (1.5") I need caster camber plates?
Old 06-12-2014, 08:09 PM   #5
The_Chech's Avatar
I would highly suggest them unless you don't wanna be buying new tires often. I maxed out my aftermarket CC plates and had to even get adjustable camber bolts to get it right where I wanted it.
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 06-12-2014, 08:16 PM   #6
The_Chech's Avatar
Put it this way too. Better to spend an extra 150-200$ on some CC plates now instead of 500-600$ on new tires and then realizing your gonna need some CC plates with them so they don't wear out like your old tires just did.
Old 06-12-2014, 08:21 PM   #7
You should really get CC plates if you are going lower at all.
Yep
Old 06-12-2014, 08:30 PM   #8
TheWitness's Avatar
Thanks for all the info guys
Old 06-12-2014, 09:10 PM   #9
XSlashDashX's Avatar
Name:	ImageUploadedByMustang Evolution1402628963.439964.jpg
ID:	159136Click image for larger version
Name:	ImageUploadedByMustang Evolution1402628981.675530.jpg
ID:	159137Click image for larger version
Name:	ImageUploadedByMustang Evolution1402628998.806293.jpg
ID:	159138Click image for larger version
Name:	ImageUploadedByMustang Evolution1402629011.115152.jpg
Here's proof you'll need CC Plates. I'll be ordering mine next week.
Old 06-12-2014, 09:36 PM   #10
And when you do order CC plates you want the Maximum Motorsports ones. Steeda is decent too but MM is better, Griggs is too damn much money but they are good too. Suspension is one area one should never ever cheap out on. Not just for your own safety but so as not to be a hazard on the road.
Old 06-13-2014, 09:38 AM   #11
Site Sponsor
OP-
It's been pretty beaten in here but Caster Camber Plates are going to be a must! Not only are they going to keep your tires from prematurely wearing but they're also going to alleviate additional unnecessary stress on your suspension. Think of them as insurance!
^^^^^^^^^^^^^^^^^^^^^^^^^^^^^This!
scottydsntknow is right on the money here-It's just not worth blowing through cash, front tires, and wasting funds on an alignment. Maximum Motorsports Caster Camber Plates are a fantastic set; These guys really know their suspension game if you haven't heard of them. Definitely worth the money as well!
-Alex
Toll Free: 1-866-363-4591
Free Same-Day Shipping!
Old 06-13-2014, 07:21 PM   #12
TheWitness's Avatar
Thanks for all the info!
Old 06-14-2014, 11:23 PM   #13
Steve96's Avatar
MM plates all the way and be done with it! One of the best couple hundred I have ever spent.
1996 GT
Caster Camber Plates or Camber Bolts OutlawGT 2005-2010 Mustang GT 18 04-05-2012 04:55 PM
Caster/Camber Plates...will they be a problem with this? Joel5.0 1979-1995 Mustang GT 4 10-22-2005 04:36 PM
Steeda Springs - Do I need caster camber plates? audioqueso Pre-2005 V6 Mustang 8 12-05-2003 05:34 PM
05:28 AM
