Window regulator problems - Mustang Evolution
Old 06-16-2014, 08:03 AM   #1
robin_gt's Avatar
Alright so about a month ago i started noticing this really loud knocking sound when the drivers side window is all the way down and you keep pressing the down button. Now a couple days ago it started getting stuck like half way through when going down and now its just a game of luck to get the window down, and if it does it goes back up without a problem so my question is if i should replace the whole window regulator or if there is another money saving fix.
robin_gt is offline   Reply With Quote
Old 06-16-2014, 08:48 PM   #2
The electric motor that powers the windows has a gear reduction unit built into it. Possibly its just that.
You'll have to take it apart and find out.
Rockauto has the motors and gear reduction.
Old 06-19-2014, 10:54 AM   #3
JCOB72's Avatar
The motor on mine died a while back. I bought the whole assembly from AM and it's worked well ever since. (Motor and regulator) I think it was a $100.
JCOB72 is offline   Reply With Quote
Old 06-22-2014, 02:05 PM   #4
xfree143's Avatar
I am also having issues on my 2003. I have replaced the driver side window motor and it worked for awhile then passenger side stopped. I was going to change the motor in it when the drivers stopped again. I actually had them both start working in the morning again then quit later that same day.
Power is all good all the way to the motors but I hear a click when you push either power button and nothing happens.
I have taken it all apart to inspect it and don't see anything wrong, I will put it all back and it will work for a while then randomly stop again.
xfree143 is offline   Reply With Quote
Old 07-28-2014, 07:56 AM   #5
I just replaced my drivers side motor and regulator. Watched a YouTube video. Easy replacement just need someone to hold up window.
Sent from my iPod touch using Mustang Evolution
Paulhagee is offline   Reply With Quote
Window Regulator Motor issue Shelton 1979-1995 Mustang GT 2 08-28-2013 10:21 PM
Wanted: 03 V6 drivers side window regulator JeremyMc77 Mustang Parts for Sale and Wanted 0 04-10-2013 10:29 PM
Window Issues - Motor or Regulator StreetJMusic Pre-2005 V6 Mustang 2 08-21-2011 12:38 PM
I need a reproduction window regulator scissor assembly for a 1967 mustang coupe.? trystan General Mustang Discussion 2 08-25-2009 04:21 AM
01:02 AM
