Driveshaft play - Mustang Evolution
Old 06-18-2014, 10:26 AM   #1
XSlashDashX's Avatar
Driveshaft play
Got an oil change today and decided to check the driveshaft because when I shift (1,2,3,4, or 5) I get a thump sound from the rear. It has play in it. Could be a bad U-Joint? Or bolts not tighten up?
Old 06-18-2014, 11:23 AM   #2
Yank on the u joint left and right and up and down. Yeah if there is play the U joint is bad. Luckily, those are easy to replace and not very expensive.
Old 06-18-2014, 11:25 AM   #3
U-Joints for Cobra and GT same?
Old 06-18-2014, 11:30 AM   #4
If there is no IRS involved yes. IIRC the rear U-joint is different on a IRS equipped car. But I'm not 100% on that so I'd do some extra research if you have IRS.
Old 06-18-2014, 11:31 AM   #5
Yea it is different between IRS and SRA
Old 06-18-2014, 11:35 AM   #6
Mile high JDF's Avatar
If they GT driveshaft was reused and a Cobra flange was put on it then you'll need a hybrid u-joint, I can't remember the size off the top of my head though. If the GT driveshaft was used and they installed a GT pinion flange on the differential then you will be fine with a normal GT u-joint
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 06-18-2014, 11:46 AM   #7
I think the hybrid U joint is like a 1310/1330 but again, not 100%.
Old 06-18-2014, 12:23 PM   #8
That's what I was thinking, but I just checked and it's a 1330/1350
Old 06-18-2014, 12:28 PM   #9
Well then there you go. Now that I think about it I think it is the T-56 27 spline yoke that is a 1310/1330. Blah.
Old 06-18-2014, 04:18 PM   #10
Name:	ImageUploadedByMustang Evolution1403129847.700397.jpg
ID:	159528Click image for larger version
Name:	ImageUploadedByMustang Evolution1403129865.300144.jpg
ID:	159529Click image for larger version
Name:	ImageUploadedByMustang Evolution1403129890.905434.jpg
ID:	159530Click image for larger version
Name:	ImageUploadedByMustang Evolution1403129913.784031.jpg
Old 06-19-2014, 10:18 AM   #11
So what y'all think I have?
Old 06-19-2014, 12:00 PM   #12
You can't diagnose a bad u joint by looking at it.
Old 06-19-2014, 01:15 PM   #13
Is it a GT driveshaft?
Old 06-19-2014, 01:19 PM   #14
It's almost guaranteed to be a GT driveshaft unless you have a 6 speed trans
Old 06-19-2014, 01:22 PM   #15
All I wanted to know. Thanks!
Old 06-22-2014, 10:03 PM   #16
edited: nvm.
Upgrade Your Weak Stock Driveshaft with The Driveshaft Shop at AmericanMuscle AMWill AmericanMuscle 1 03-16-2014 02:18 PM
Any of you play Star Wars Battlefront? SpectorV The Bar 5 12-07-2004 11:12 PM
Anyone on here play Medal Of Honner Allied Assault SpectorV The Bar 6 06-28-2004 08:47 PM
clutch play 66burningrice Classic Mustangs 2 05-28-2004 06:31 PM
So does anyone on here play counter strike? Brent The Bar 24 03-24-2004 05:19 PM
08:53 PM
