Sticking Gauges - Mustang Evolution
Old 06-20-2014, 06:20 AM   #1
M4ttyIce16's Avatar
Sticking Gauges
So last night I installed the white face gauges on my 2001 mustang gt. I pulled the needles off to make it easier to put the white face on but I never touched the needle that goes down into the motor trying to keep from messing anything up. But I still managed to mess it up hah. My gauges are sticky and full gauge says it's over half full wen I'm really below a half a tank speedo won't fall below 3000 and rpm won't fall below 3500 oil temp and all those are stuck on high. What did I do and how do I fix it? Click image for larger version
Name:	ImageUploadedByMustang Evolution1403266837.956853.jpg
M4ttyIce16 is offline   Reply With Quote
Old 06-20-2014, 07:02 AM   #2
You pull the needles back off and put them back on without pushing down all the way. Need to leave a gap. When I did my white faces I pulled the old black faces off, no point in leaving them and it helps with issues like this.
Old 06-20-2014, 08:29 AM   #3
M4ttyIce16's Avatar
Mine were just the stickers that you line up but thank you I'll get at it when I get off work and let you know how it goes. Thank you
Old 06-20-2014, 11:59 AM   #4
All the white faces are, but so are the stock black gauges. You can rip off the black ones and put the white ones right over provided they are actual white face replacements like the MACs.
But if not just reset the needles so they aren't so close to the gauges and make sure the actual holes they go in aren't being constricted by the new pieces.
Old 06-20-2014, 12:00 PM   #5
M4ttyIce16's Avatar
Oh I didn't know that, thank you
Old 06-20-2014, 12:02 PM   #6
Yeah they should have guide holes that line up on the plastic and go right in. My $30 MAC gauges did and they look OEM. Ppl think I swapped in a Cobra cluster which is why (IMO) swapping in a real Cobra cluster is idiotic.
Old 06-22-2014, 08:52 AM   #7
parkerz28's Avatar
Name:	ImageUploadedByMustang Evolution1403448508.256765.jpg
ID:	159795Click image for larger version
Name:	ImageUploadedByMustang Evolution1403448597.394816.jpg
These are what I have in my car looks almost identical to cobras. The best part is they come in 3 pieces so you don't have to remove the needles. Once you remove the needles it is almost impossible to put them back in the right position. To me awhile to find these but well worth it
parkerz28 is offline   Reply With Quote
Old 06-22-2014, 08:53 AM   #8
parkerz28's Avatar
Hate auto correct. Took me awhile to find those
Acts like the choke is sticking bizwaks 1979-1995 Mustang GT 0 03-20-2011 02:38 PM
Gas peddle or throttle sticking Myles 1996-2004 Mustang GT 14 01-10-2011 06:26 PM
Idle sticking Rascal Pre-2005 V6 Mustang 2 08-11-2010 02:18 PM
Cruise Control Sticking meteorachick Pre-2005 V6 Mustang 19 06-19-2008 05:39 PM
Clutch sticking to Pressure Plate??? Rick0636 Pre-2005 V6 Mustang 5 11-08-2003 06:28 PM
02:03 PM
