Installing rotors - Mustang Evolution
Old 06-21-2014, 03:03 PM   #1
Tangtang2.0's Avatar
Installing rotors
So I just picked up these rotors for 150 .. And I was wondering how hard using to install em and what do I have to do
Tangtang2.0 is offline   Reply With Quote
Old 06-21-2014, 03:18 PM   #2
escottcarp's Avatar
Changing brake pads and/or rotors is very easy. I'd suggest you check out the numerous videos on YouTube. It's actually hard to mess it up.
escottcarp is offline   Reply With Quote
Old 06-21-2014, 03:22 PM   #3
Ok good I'll look into it thanks for the advice
Old 06-21-2014, 05:00 PM   #4
Super easy... it takes longer to jack up the car and remove the wheels than it does to change the rotor.
2 bolts hold the caliper on, after thats off, the rotor just slides off the lugs.
Are you changing pads too?
2012 Mustang Cyclone, 2002 Mustang GT, 2004 F150 FX4, 1999 Ranger O/R 4x4, 2007 Harley FXDB
jefx is offline   Reply With Quote
Old 06-21-2014, 05:01 PM   #5
No I gottem changed less than 2 months ago
Old 06-21-2014, 05:03 PM   #6
You didnt link the rotors.
I just put these on the front of mine with matching ceramic pads.....works awesome.
---------- Post added at 06:03 PM ---------- Previous post was at 06:03 PM ----------
Than why are you changing rotors?
Old 06-21-2014, 05:04 PM   #7
I have an oem rotor.. The ones I bought look better
Old 06-21-2014, 05:06 PM   #8
Most rotors come from the factory with a gooey glaze on them that needs to be cleaned off with brakes parts cleaner. However, performance rotors are often "ready to use"... check the label and item description to see if they need to be cleaned first
Old 06-21-2014, 05:11 PM   #9
Hmm. you are going to run into a slight problem then.
The old pads and calipers will have some wear, so the calipers wont slide over your new rotors as is.... You will have to remove the brake fluid canister cap and press the caliper pistons out to refit everything.
Old 06-22-2014, 09:03 PM   #10
Which takes all of 2 seconds with a big pair of channel lock pliers.
Honestly the OEM style rotors work great and changing them out for some crazy drilled/slotted ones is a waste of $150 IMO and also you lose braking surface with the holes/slots in the rotor. I pay $30 a rotor on Rockauto for really good Raybestos ones and the car stops very well.
Just my $.02, take it for what its worth.
Installing Brake Pads and Rotors Mustang414 Pre-2005 V6 Mustang 13 05-21-2005 06:04 PM
WTB: Baer 13" cross drilled rotors 1bad281 Mustang Parts for Sale and Wanted 1 01-31-2005 03:41 PM
Got my new calipers and rotors today **with pics** SpectorV Pre-2005 V6 Mustang 17 06-10-2004 05:42 PM
Brembo Sport Slotted Rotors (Rear) Hawk Pads mattstang Mustang Parts for Sale and Wanted 7 04-30-2004 07:08 PM
Need Pics of 13" brembo rotors installed!! Autobadges.com The Bar 21 12-14-2003 04:32 PM
03:44 PM
