T-45 install problems - Mustang Evolution
Old 06-21-2014, 05:15 PM   #1
mattski's Avatar
okay so i pulled the motor to rebuild it and took the transmission out to ease the process of putting it back in. now im having one hell of a time putting it back in. i have a transmission jack and have it going in pretty good. im thinking its just a matter of the angle its going in. running into problems ie things getting in the way like the spacer plate and the bracket that sits on top. it is wedged in between the transmission and the car and now the trans doesnt want to come back out. any advice on how to make things easier would be much appreciated.
mattski is offline   Reply With Quote
Old 06-22-2014, 08:48 PM   #2
Are you going in from underneath or dropping it all in at once? If going in from underneath, just disconnect your air intake from the throttle body and put a small jack under the front of the oil pan and jack up the front of the motor till the rear of the motor just kisses the firewall. At this point the trans should be going in at a pretty good angle and you should have plenty of room. I just put a 3650 in this way and the 3650 is a little bigger than the T-45 and it went right in.
Old 06-22-2014, 09:08 PM   #3
mattski's Avatar
From the bottom. Got it in but my only question now is that the motor doesn't turn over while it's connected.
Sent from my LG-D800 using Mustang Evolution mobile app
Problems with tune after install mods (CAI, TB, Plenum, etc) reboot4ever 1996-2004 Mustang GT 9 10-11-2013 01:38 PM
Steeda tri-ax shifter install problems 2013_5.0_GT 2011-2014 Mustang GT 6 09-29-2013 11:53 AM
how hard to install o/r x pipe? how much to get x pipe install? MustangForEver 2011-2014 Mustang GT 9 02-05-2013 07:01 PM
Problems and more problems BigB227 1996-2004 Mustang GT 1 08-22-2012 09:12 AM
Computer problems :) hehhe MusclesFromBrussels The Bar 11 07-15-2003 10:20 PM
09:25 AM
