Sensor 2 Bank 1 question. - Mustang Evolution
Old 06-21-2014, 05:30 PM   #1
Kbasham5's Avatar
Ok guys. Wanna see if anybody can help me out. I recently had my check engine light come on my 01 GT and my car will miss occasionally when running at cruising speed. It's not a real bad miss but it's noticeably then it will go away. I went to the local mechanic and he hooked up the scanner and said it was sensor 2 bank 1. Would that cause my car to miss? I didn't think a downstream 02 sensor would cause it to miss but I might be wrong. Thanks in advance!!
Kbasham5 is offline   Reply With Quote
Old 06-21-2014, 05:45 PM   #2
If thats what the scanner reads, then its probably the problem. The 02 sensors help regulate air/fuel ratio. An improper ratio could cause misfire symptoms.
2012 Mustang Cyclone, 2002 Mustang GT, 2004 F150 FX4, 1999 Ranger O/R 4x4, 2007 Harley FXDB
jefx is offline   Reply With Quote
Old 06-21-2014, 05:47 PM   #3
Kbasham5's Avatar
The down stream 02 sensors are only to make sure the cats are working from what I understand. The upstream sensors do monitor air/fuel ratio.
Old 06-21-2014, 05:54 PM   #4
Either way, the car is misfiring, and the scanner says o2 sensor... That would be the first part I change.
Old 06-21-2014, 07:11 PM   #5
Hellish Horse's Avatar
I had a bad 02 sensor in my 04 V6 & it made it run a little crappier. Not absolutely positive but I think that's the Drivers side Front Sensor. You might want to pull & clean your MAF Sensor while you're at it as a dirty one will make your car run like chit !!!
If you're running a C.A.I. clean the air filter too. You'll see an improvement for sure.
Hellish Horse is offline   Reply With Quote
Where is the bank 2 sensor 1 oxygen sensor located? BIG R 2005-2010 Mustang GT 2 10-04-2013 04:46 PM
Bank 1 and bank 2 running lean. Rich04 1996-2004 Mustang GT 19 04-23-2013 07:20 PM
crank angle sensor/camshaft position sensor instalation 1996v6stang Pre-2005 V6 Mustang 0 11-03-2011 05:57 PM
oldest bank robber tire The Bar 7 03-29-2004 04:12 PM
The Frog and the bank loan n8r The Bar 5 03-17-2004 08:06 PM
» Members Mustangs
Bruce
Justin72
Shelly
Dodd
Add your Mustang
08:43 PM
