Intake Manifold - Mustang Evolution
Old 06-25-2014, 12:34 PM   #1
Intake Manifold
What Manifold would actually make a difference and how
Ford Racing Performance Improvement Intake
Replacement PI Intake Manifold
Edelbrock Victor Jr. EFI Intake Manifold
Professional Products Typhoon Intake Manifold
Dorman
Trick Flow Track Heat Aluminum Intake Manifold
TurboCobra is offline   Reply With Quote
Old 06-25-2014, 12:48 PM   #2
The first intake is the same intake that comes on all 99-04 cars (updated in 01 with the metal crossover).
The second intake is the Dorman (junk)
The third intake will gain you some up top with the cost of power down low which is bad for a bolt on 2V.
The 4th intake is Chinese garbage
The 5th intake is the Dorman which is a NPI intake for all intents and purposes and crap.
The Trick flow is an attempt to copy the Bullitt intake and isn't really that great.
If you are a 99-04 stick with the stock (PI) intake. It is not restrictive and you will not see any benefit to switching intakes even with new heads. If you want to upgrade your intlet tract spend your money on a good plenum/tb combo (trick flow for $279 on Summit) and a cold air fenderwell intake.
Boss intake manifold and the stock intake Yellow50 2011-2014 Mustang GT 43 04-26-2012 06:30 AM
Intake Manifold vs Intake Man-child jbanks 1996-2004 Mustang GT 17 08-02-2011 04:55 AM
Ported Intake Manifold..STRESS 99'sleeper Pre-2005 V6 Mustang 5 03-10-2005 08:10 AM
95 Intake manifold. Calston31 Pre-2005 V6 Mustang 6 12-05-2004 05:42 AM
Intake manifold and cylinder head jwscorpio Pre-2005 V6 Mustang 4 02-27-2004 06:49 AM
10:22 AM
