99 cobra sputtering? - Mustang Evolution
Old 06-26-2014, 10:10 PM   #1
Jsansom's Avatar
I just got a 99 cobra was told that the engine light was on due to no mil elimenators.. So I ordered so. Well yesterday I had the car on jack stands getting new wheels so I crawled under it and the front o2 sensors r connected.. So my question is what is causing it to sputter? I thought it would be bc of no o2 sensors?
Jsansom is offline   Reply With Quote
Old 06-26-2014, 10:47 PM   #2
PonyBoyV6's Avatar
Could be a couple things. Most likely not getting enough fuel, or not getting enough spark. To start, Give the car a complete tune up. Change the plugs, Replace the fuel filter, change the fluids and oil. And if that doesn't help it, It could be any number of things regarding air/fuel/or spark. If you really wanna make life easy, have the CEL read. That'll give you a great place to start. But regardless, you should give the car a basic tune up anyway.
PonyBoyV6 is offline   Reply With Quote
Old 06-27-2014, 05:01 AM   #3
fwalck's Avatar
The mil eliminators are for the rear o2 sensors anyway to make your car think you have cats on when your don't.
fwalck is offline   Reply With Quote
Old 06-27-2014, 09:30 AM   #4
Jsansom's Avatar
The car only does it when I'm cruzin around. If I get on it. It's stutters a lil bit then goes..
Old 06-27-2014, 09:48 AM   #5
Jsansom's Avatar
Name:	ImageUploadedByMustang Evolution1403884008.687719.jpg
ID:	160168Click image for larger version
Name:	ImageUploadedByMustang Evolution1403884038.442269.jpg
ID:	160169Click image for larger version
Name:	ImageUploadedByMustang Evolution1403884049.175448.jpg
ID:	160170Click image for larger version
Name:	ImageUploadedByMustang Evolution1403884063.824065.jpg
ID:	160171Click image for larger version
Name:	ImageUploadedByMustang Evolution1403884075.523342.jpg
Ran the codes on the car and got this?
Old 06-29-2014, 12:48 AM   #6
PonyBoyV6's Avatar
Man, I'll be honest. I've personally never come across those codes before. Only thing I can gather from that is the car is probably running pig rich. Why? I have no idea, but here's a free bump to your thread, hoping that someone can help you out.
Edit: Upon looking into your P0602 code some more, I found on various forums that your PCM could be corrupted and need to be reflashed. Not 100% sure on this, But It's a start. Certainly would explain your symptoms to a T, from what I've been reading.
Do you have an Aftermarket tune on your cobra? If So, try resetting it to stock and see what happens. If NOT, then I would take it to a trusted Ford dealership to have it reflashed.
Old 06-29-2014, 08:09 AM   #7
Jsansom's Avatar
That's what I was thinkn that maybe the car has a crap tune. So I was thinkn bout gettin it flashed then retuned with bama.. They have nvr let me down beofre
skip-sputtering Sn95er 1996-2004 Mustang GT 3 10-10-2011 11:53 AM
Still sputtering... 04SonicBlueGT 1996-2004 Mustang GT 7 11-30-2009 12:25 AM
Sputtering 04SonicBlueGT 1996-2004 Mustang GT 5 11-15-2009 07:24 PM
sputtering at low rpms eddie1 1996-2004 Mustang GT 28 05-12-2009 08:22 PM
sputtering Stang!! jagger969 1979-1995 Mustang GT 2 04-09-2008 09:02 PM
01:55 PM
