T45 not shifting - Mustang Evolution
Old 06-27-2014, 08:48 PM   #1
mattski's Avatar
T45 not shifting
I installed my tranny and now it doesn't engage the gears. It will shift through the gears and everything but now it wont engage. I can shift through the gears with the motor running and not pushing the clutch in.
Thinking maybe the throw out bearing or pressure plate?
Help would be greatly appreciated
Sent from my LG-D800 using Mustang Evolution mobile app
mattski is offline   Reply With Quote
Old 06-27-2014, 10:56 PM   #2
If you can shift without pushing the clutch in you did something very wrong with the clutch/tob/fork assembly and it has to come out and see wth you did. Unless your clutch cable is so tight its keeping the clutch permanently engaged or something...
Old 06-27-2014, 11:38 PM   #3
mattski's Avatar
I loosened it and looked in by the fork. I pulled the fork back and the throw out bearing slowly moved forward towards the pressure plate. I'm thinking the clutch plate might not be completely aligned? And not allowing it to engage
Old 08-01-2014, 01:11 PM   #4
mattski's Avatar
Turns out my clutch disc was FUBAR
Old 08-01-2014, 01:53 PM   #5
That'll do it... Upgrade clutch, new flywheel, make damn sure its installed/torqued properly and off you go. I'm doing a clutch myself in the next weekend or two. Just need to find a time the old man can help me drop the trans yet again...
Good budget combo is the Exedy Mach 400 and an OEM nodular flywheel. You can get both on AM.
Power Shifting vs Quick Shifting BlueDemon 2011-2014 Mustang GT 10 06-02-2016 09:50 AM
Rough Shifting / Not Getting into Gear JoeyM91 2011-2014 V6 Mustang 13 05-23-2014 11:59 AM
TPS Low Voltage, Not shifting from second gear? 3.8Monster Pre-2005 V6 Mustang 0 05-24-2013 02:55 PM
Barton shifter not shifting??? Charged13 2011-2014 Mustang GT 11 11-01-2012 04:04 AM
1976 ford mustang will not start, not headlights come on, it is not the battery, why? eifion Classic Mustangs 6 08-24-2009 03:12 AM
09:22 AM
